Sat Newbie jumped in with both feet :)
  • Jocky666
    • 119
    Hi guys very new to sat, have been playing with calbe for a while, mainly because the Internet is the fastest round here and also dreamboxes were cheap as chips!
    Recently got hold of a sat system comprising:
    1.8m Segmented dish
    TM 5500 CIP
    polar mount
    ground stand
    18" actuator
    dual output LNB
    Now I know the TM5500 isn't supported by the community anymore, however it does drive the actuatore natively i.e. no need for a v-box.
    Now since I'm more grounded in linux boxes can anyone recommend a box that could replace this TM without the need for a v-box?
    Failing that what would you recommend I replace the TM with?
    I want to unlock as much as possible especially sports feeds and would also like the ability to Blind scan (for feed hunting), I am aware of the C/S route and the ban on discussing it on here but it would still be a nice option to have!
    I have looked at the IcecryptS4000 and dreambox 7020s but am frankly puzzled as to what is needed/box / image / files etc. to make the absolute most out of my setup??
    Any help rendered is truely appreciated!!
    cheers
    Jocky666
  • satsid
    • Aug 2009
    • 815
    1.8m Segmented dish
    TM 5500 CIP
    polar mount
    ground stand
    18" actuator
    dual output LNB
    cheers
    Jocky666
    Hi mate,18 inch jack on a 1.8 dish might not be good if your dish get's strong winds,i hope it's a havey duty jack @ least.Dual output LNB.i take your mean a twin lnb.If disec will move your dish from receiver hmmmmmmm,not sure if it will?????as iv always used 36 volts.It's one receiver to move dish & another to watch from i would say is best.You want feeds,now im the one to ask here.Receiver its got to be a Azbox as it will do 4.2.2 for you.Blind scan has been said to come on Azbox,but so far that's been bull,but its a good box all the same.
    • satsid
      • Aug 2009
      • 815
      Here a pic for you of my dish,this has a 24 inch havey duty jack.C120 feedhorn & invacom lnb work good with that size dish.
      • Jocky666
        • 119
        Cheers SatSid
        Hi Sid thanks for the response appreciate it mate!
        This is the actual description of the actuator and LNB
        heavy-duty 18" Superjack actuator,polar mount,twin output 0.3 LNB.
        Any Good??
        How bigs ur frisbee?
        an AZ box it is then any particular model you'd reccommend?
        This is a pic of the back of the box!
        Are AZ boxes Linux based? can they be Networked for obvious reasons?
        Cheers
        For the feedback mate !!
        Jocky666
        • benny/9
          • 1964
          as far as i know all the satellite linux boxes
          support a diseqc motor only, but v-boxes are
          dirt cheap and they convert diseqc to 36v
          without any problems and the receiver moves
          the dish very fast via the v-box.i use the gbox v-box
          and they are about ?39 and even cheaper from a bid
          on the bay it's far better than useing a old box to move
          the dish and looping to the new box
          3
          Please Read Carefully!
          • Jocky666
            • 119
            Thanks Benny!
            Yes I saw the price of the V-boxes as you say dirt cheap!
            So its gonna be the way to go I suppose!
            still trying to decide whetehr to go with AZbox of maybe a dream 7025s??
            Just so many to choose from LOL
            I'll make my mind up one day
            • Jocky666
              • 119
              Ok So I have decided definately to go with a Linux box, as I understand it some have better support than others including Emu's etc.
              Dream is the obvious (Ithink) leader in the Support department but pretty expensive !
              Azboxes look pretty cool and with 422 compatability would be good for feed hunting!
              the real question now is what boxes do you guys think have longer term prospects and which would be best for the darker side of sats??
              Oh one last question the AZ box has a couple of models and not too different in price, if recommending an AZ which model do you think or for any other brand for that matter!
              • alec
                • 345
                With your equipment , I would recommend a clone DM800 from a good source, or a VU+DUO. I set up my system with the Vbox outside with a meter. Just set up roughly on the Vbox and limits. Then fine tune inside on the receiver. You can count the numbers of Vbox between two Sats to work out the next Sat if the Dish is tracking correct.
                • Jocky666
                  • 119
                  OK so I took the plunge and did a deal with a guy on a certain auction site, I got an AZbox premium for ?180 , not the premium + sadly so no hardware blind scan but hey I think its a good deal as it will most likely make my HDX 1000 NMT redundant, meaning I should be-able to sell that for about ?120, if it works out right I should only be down about ?60!! Happy days!!
                  Any way now its time to start looking into setting up the hardware, dish etc.
                  and with that I would like to ask if anyone can recommend a good guide for this sort of thing??? i.e. dish positioning, actuator fitting etc. The arc is supposed to already be set up though I'm mych further north than the original owner! remmember its a 1.8m actuator driven dish, I know I need a v-box for it (any recommendations, perhaps a forum sponsor??).
                  I'm good a running cables etc. but the more technical side of this setup will take some reading up, failing that I'm in the Wolvehampton area, if anyone can recommend a good fitter then please PM me!?? As most of the guys I've enquired with aren't interested unless its a mini dish you need putting up!!!
                  As always any suggestions are most welcome!!
                  Cheers
                  Jocky666
                  • satsid
                    • Aug 2009
                    • 815
                    Any Good??
                    Cheers
                    Jocky666
                    Hi m8,sorry not been around for abit as iv been painting the house.Actuator on back of that box is for 36 volts,put your 4 core wire in that to move your dish.heavy-duty 18" Superjack might be ok,if not happy when windy move up to the 24 inch.
                    • Jocky666
                      • 119
                      Hi Sid thanks for the reply!
                      I'm looking at getting a v-box now though, save having 2 different remotes just to move the dish... unless the TM is capable of taking the commands from the AZbox?? but I can't find anything to suppost that! any recommendation on a v-box?
                      Also any idea on setup instructions for the dish??
                      Jocky666
                      • Jocky666
                        • 119
                        Any idea's fella's and ladies??
                        HI fella's
                        Right below is a screenie from dishpointer showing 13 deg east for hotbird 6-9 can anyone see any issues with the location of the dish?? I'd like to get as many sats as p[ossible but since its at ground level there are obvious obsticles like houses etc!
                        If you can take a look for me and possible recommend a better location in my garden I would appreciate it !Many thanks
                        Jocky666
                        Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
                        FYI Sid brought an AZbox premium ?180 ;-)
