does the scew on ur lnb not need to be changed when changing to different satellites with motorised dish?
no m8 as when the dish moves left or right it also tilts aswell which also alters the skew of the lnb. aas long as the skew is set correctly when you set the dish/motor on 1 west you will be fine. regards mdt
Generally most dishes are set up on 1 west in the UK as it is the centre of the arc.
You could set up on another sat but 1 west is best.
Set up on BB World fta 1 west for best results.
