motor dodgy ?
  • OldBloke
    • Sep 2009
    • 162
    motor dodgy ?
    Hi men,anyone had a motor go kaput on them ?
    Mines not a yr old yet,say about 7-8 months.
    When its arcing to a new position it doesnt glide it kind of stutters and jerks..sometimes it doesnt make it to the new position and I have to go into the motor menu and drive it there again ?
    Looks like its on the way out ?
    Is there anything I can do ? or is it a new one needed ?
    Spiderbox ,1m motorised dish...
  • Manic01
    • 5117
    That is normally insufficient power from the power supply of stb.
    As the TM5400 has sufficient power I would try using Diseqc instead of usals and see if that helps.
    • hypersonic
      • 254
      Dodgy motor ?
      Could be a bad connection anywhere between your STB and the motor or maybe water ingress to the cable.
      • OldBloke
        • Sep 2009
        • 162
        Manic,you might be onto something there mate,its only since I had the sb7000 its started happening,will change the stb and see if its still the same,ty mate
        • yamar1
          • 970
          try moving it with the manual buttons on the motor. if it moves ok you then know the problem isnt the motor.
          Faster than Faster
