WTF
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    WTF
    Right.. I got a real problem here at the mo. I have lost signal for every channel on thor. I have checked all the other sats and they seem to work fine. But most wierd is that the other sats work but my ref sat doesnt. Can somebody check that these channels are still up and running. Now i will have to wastbi the arsenal game via stream. Will anyone stream?
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • aftermath
    • 4345
    PMSL , i had this the other day, lost the whole lot, i waited till later that evening and scanned them all back.
    Just wait a while, i heard a few peeps been losing Thor.
    I will check mine now and get back m8.
    • .: JaCkPoT :.
      • 5607
      I lost it just when i need it. All the arsenal games were on premiere but today theyre showing liverpool so i needed thor, checked but all is gone.
      ___________________
      DM800s HD
      Openbox S10
      TM500
      DM500s
      Maxx 110cm Dish
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Is it available on softcam?
        • aftermath
          • 4345
          The Liverpool game is advertised as being on Premier Sport Portal 19.2e
          also Prima TV 19.e. , 23.5e. and 1.0w
          i watched a game on Prima TV 1.0w 2 weeks ago, it was spot on, but Premier Portal has better Pic.
          • .: JaCkPoT :.
            • 5607
            Ye. Available on softcam. Btw i wanna watch arsenal match not liverpool. Thanks 4 checkin. Will try b4 kick off again.
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              It's dead for me aswell then.
              • .: JaCkPoT :.
                • 5607
                Signal or descrambling?
                Its my signal which is gone
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  What channel is it specifically? BBC World is working for me on Thor and the other channels are just not clearing but the SNR is about 70%.
                  • .: JaCkPoT :.
                    • 5607
                    Sorry for late response. Noting at all was working but guess what time it got sorted?
                    Approximately 10mins after the arsenal game finished.. how cra.p
                    ___________________
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    Maxx 110cm Dish
                    • Curious123
                      • 2591
                      I had this problem a few weeks ago whereby I could not get anything on 1.0W Thor. The reason for the problem is that the channel settings satellite.xml and the image makers satellite are slightly different so it is unable to pick up the channels though that does not explain why aftermath was able to get the channels later on in the evening. Try adding the satellite manually by following the instructions below;
                      You could try adding the sat manually as it worked for me. Posted by digidude on another forum
                      AFTER downloading the captain channel list
                      press menu
                      setup
                      sat config
                      highlight 0.8W and press the red button to erase it
                      press the yellow button, a new box will appear at the bottom with a random satellite in it
                      press ok
                      scroll down to 1.0W
                      press ok
                      press green to save
                      press exit
                      go down to auto transponder scan
                      press ok
                      now in the list you should have 1.0W, highlight it and press ok
                      wait for a transponder lock
                      press green to scan
