Is the a linux receiver with built in actuator motor positioner?
  • Sicilian
    • 168
    As the title guys, i'm after a linux receiver with built in positioner to control a actuator motor. This is for a family member who is not that technical so really dont want to go down the route of a dreambox & seperate positioner if it can be avoided.
    The dish installed is a big 1.2m channel master which I think is too heavy for a diseqc motor & dont really want to go through the hassle of swapping that either.
    Let me know whats available please.
    Thank you in advance.
    D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5611
    Buy a metal gear motor. Most motors hold upto 1.2 but metal gears hold 1.3 i think so it should work so long as you use a pair of t&k brackets.
    The most simple receiver is the new technomate 5000 series receiver. The 5300usb with 2 multicrypt card reader.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • macssam
      • 13
      which Receiver moves a 24" actuator arm properly
      which receiver can move a 12"-36" actuator arm motor
      for a 3m/10ft dish properly without adding any boxes
      16 years ago I owned a "strong" receiver
      which had a built in positioner tp store satellite positions
      it had a separate 24volt outlet to move a 12"-36" actuator motor arm
      can any of these receivers move a 12"-36" actuator motor arm for a 3m/10ft dish
      VIEWSAT FTA 9000HD - SONICVIEW FTA SV-8000
      which is the best FTA receiver ...
      -sam-
