it should open ok are you using one of the later patches these can stop digi opening.go back to one of the earlier patches and try again. I use patch 688p to open digi on my 6800HD original as the later ones block it.
Well i have tried every angle and still can't get things to open What am I doing wrong or has Thor gone ?
hi m8, thor is still clearing using the latest softcam. if you are using a patch were you know that digi-tv is ok and you have turned off the digi a.u. function then it should be clearing. try this patch, i know it is old but it is stable. regards mdt
