how do i scann for terrestial channells on my sat box ,
  • ranger
    • 178
    hi , i have a technomate, sat reciver box , it has all of the fta channells working fine, from the dish, but i cant find anywere in the menu, were i can scann for terrestial channells? it has ANT/and rf out uhf 21-69. ports on the back next to the scart, i have went throught the menu, on the installation . but cant find how to run a scann for the terrestial channells , can anybody help me ,, thanks
  • cactikid
    • 12017
    if it does not have a terrestrial tuner you cannot scan,post what model to be sure as some have 3 tuners
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5607
      6000Hd combo does have terrestrial tuner
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • ranger
        • 178
        the model that im try to scann for terrestial channells , is (Technomate TM 1000D , can anybody tell me if it has a terrestial tuner ? thanks ,,,
        • Elric
          V.I.P. soft lad
          • 853
          Technomate TM1000D
          Price: ?79.00 (including VAT @ 17.5%)
          Availability: Available
          [Technomate TM1000D]
          Free To Air Satellite receiver with Blind Search, 5000 Channels, SPDIF Digital Audio, USALS/DiSEqC 1.2, Auto Navigation, TV OUT
          Features
          * One of the fastest receiver ever
          * 280mm x 55mm x 235mm
          * Blind Search (power scan)
          * Free to Air (FTA)
          * Less than 1 Second channel change
          * Up to 70 Satellites and 5,000 channels
          * 65mbit sd ram total memory
          * Fully DVB compliant
          * DiSEqC Indicator
          * Multi-Event Timer
          * Full navigation auto finding and auto tuning
          * Full navigation blind search auto finding and auto tuning
          * Super Sensitive tuner for very weak signals
          * On Screen diseqc and usals positioner display- moves dish incase of rain and bad wheather
          * Auto satellite finder- just turn usals ON and select, for example, HotBird and it will find it instantly
          * High quality video and sound by MPEG-2 standard
          * Easy-to-use menu system with comments for guide
          * Channel deleting, moving and sorting functions
          * Automatic digital Satellite signal detecting Function
          * Separate automatic search for newly added transponders and channels
          * Multiple switch types, LNB types and NTSC/PAL Monitor types
          * Manual editing function of Transponder Information
          * Support PAL/NTSC system
          * Parent control function
          * Last channel auto-saving and recall function
          * Satellite name-change function
          * Hi-speed software upgrade through RS-232(NULL Modem)
          * Receiver-to-receiver data transfer via RS232
          * PLL type RF-Modulator (Ch. 21- 69) and UHF tuning function
          * Favourite Channel function
          * Antenna-positioning-help function
          * Timer Function
          * Teletext Function
          * Automatic FEC and PID detection and manual entry of PID value
          * Pause function
          * Loop through tuner and satellite
          * Real Time Clock
          * Multi-Language OSD
          * Delete Function subtitle supported by osd & vbi
          * 8 Favourite Channel grouping and sorting function
          Specification
          System Capabilities
          Fully DVB compliant
          Channel Capacity
          Digital Max 5000CH
          Demodulator
          Type: QPSK & FEC or DVB pr ETS 300 421
          Symbol Rate: 2-45 Msps
          SCPC & MCPC: Capable
          Video Processing
          MPEG-2 Main Profile @ Main Level
          Video & System Memory: 64Mbits of SDRAM
          Data Rate: Upto 15Mbits/s
          Video Output: NTSC/PAL (Auto)
          Pixel: 720x480 @ 30fps & 720x576 @ 25fps
          Video Format: 4:3 & 16:9
          Audio Processing
          MPEG-2 Layer I and II
          Mono, Stereo Channel, Dual Mono
          TV Scart
          RGB, CVBS, Audio L/R
          VCR Scart
          CVBS, Audio L/R
          LNB & Tuner Input
          Input Frequency: 950 to 2150 MHz
          LNB Supply: 13/18V, Max. 400mA
          Band Switch Control: 22KHz
          DiSEqC: 1.0 & 1.2 Compatible
          Connector: 2x F-Type & 3/8-32UNEF-2A
          Data Service Port
          Connector: 9-Pin D-Sub
          Data Protocol: RS232C
          Data Rate: 19,200 Bit/s
          On Screen Display
          On Screen Display
          256 Color per Display
          Bit-mapped Type
          720x576 Pixels
          Remote Control
          Operating Distance: Upto 10M
          Batteries: 2x 1.5V (AAA Type)
          Power Supply
          Type: Switching Mode
          Input Voltage: 95-265V AC, 50-60Hz
          Nominal Power Consumption: 25W, 140W (Positioner)
          Connector Summary
          1x LNB Input (F-Type)
          1x IF Output (F-Type)
          2x Scart (TV/VCR)
          1x 0/12 Volt (RCA)
          1x Video Output (RCA)
          2x Audio L/R (RCA)
          1x RS-232 (9-pin D-sub Female)
          1x RF-Modulator TV Output
          1x RF-Modulator Antenna Input
          1x Push Terminal (Skew)
          1x Push Terminal (Positioner)
          Dimensions (W x D x H)
          370 x 273 x 60mm
          Weight
          3.2Kg
          • Manic01
            • 5117
            That is for an aerial to pass in and sat signal to pass out.
            Only 1 tuner sorry.
            • cactikid
              • 12017
              correct i have 2 old models here ,only a sat tuner.
              • ranger
                • 178
                thanks for all your answers , on my question,, ill get a different model . ranger
