curious
  • buzzking5
    • 146
    curious
    on the estate where i live the council have fitted these boxes so i can either get free view or s*y without having to put a dish or arial up it runs from source they supply...is there any type of box out there i can get to use to use on the satalite feed...any help be great... thanks
  • dick b
    • Jun 2009
    • 2462
    the sat feed will be for 28.2/5 East so either a sky box,freesat box or any FTA sat box set to 28.2 will work.your best option would be in my opinion an HD freesat box but others may differ.
    • mdt
      • 3034
      you may want to check if it works first before spending your money m8. a company called avonline did the flats around here including mine and it doesnt even work properly. 38 channels on a scan of astra2 and 35 on freeview. i could have done a better job with a octo-lnb and a couple of mast-head amps. get yourself a tm600 and then google c/s to find out the possabilities. regards mdt
      • buzzking5
        • 146
        it was avonline who done the set up here as well mate thanks for that post
