Is This Maplins Wall Bracket Any Good
  • girovend
    • 158
    I had a go at putting up my dish today but the wall bracket I was using although sturdy was shite,
    Took a run over to Maplins and saw this
    45cm Cranked Bracket : Satellite Accessories : Maplin
    its made by Metronic , it looks ok but it feels flimsy , as if If I were to tighten the dish up it would actually collapse the pole,
    Maybe just me though as this is my first attempt at a satellite install, anybody
    tried one or think it would be ok to use
    buy one, if it falls off the wall, then the answer is no.
    • girovend
      • 158
      Many thanks half wit, I have bought one just not used it yet
        Thanks for the compliment.
        well take it back then
        • mdt
          • 3034
          hi, i would always choose a t+k arrangement but have installed 1 meter motorised dishes and used similar L shaped brackets without any problems. are you using a fixed dish or motorised? as long as you can get the bracket 100% plumb for a motorised system and it is not holding to much weight then it will be fine. regards mdt
            It seems ok but as mdt says T&K brackets are better and give you that litttle bit extra adjustment to get your pole 100% plumb, which is essential on a motorised dish. I think i paid around the same price for the T&K brackets as that cranked one. Might be just as well getting the T&K brackets if you can.
            • Manic01
              • 5117
              I use one similar to this for motorised set up.
              Works a treat.
              wall bracket for satellite dish on eBay (end time 30-Jul-10 16:55:56 BST)
              Wouldn't pay that much though.
