weird issue with dreambox 800hd
  • rossi2000
    • 37
    good morning
    i have a dm500s which works perfectly on my sat
    i want to go hd and have recently tried 2 different dm800hd's (clone and original (4 different images)) both give me the same results, i lose over 70% of the channels.
    the only hd channels that will work are bbc and itv, channel4 and five will not work, and then i lose almost every sd channel aswell.
    the snr just drops to 0 on most channels and the ones that do work range from 50-70% snr, even with an inline amp too this makes no difference. i can plug my dm500 back in and its fine again. i'm in apartments so have a communal dish but have been told this shouldnt really affect things
    i dont want to buy another brand of hd box such as vu+ solo in case i get the same issues. i would of thought the dm800s would just work.
    i am going to try an original sky hd box later today which i should be able to recieve the freeview hd on. i'm kinda hoping it doenst work so i know i have signal issues or something but if it does work and i'm stuck again.
    does anyone have any ideas what could be causing this?
    TIA!!
  • the man
    • 1660
    you may need a inline amp,
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5607
      Try a 13db\18db inline amp
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • karlpowell
        • 189
        it was my dm800 he tested it with , could it be that the dish is pointing at 28.5 and NOT 28.2 ? .
        as we did a manual scan it went to 50/60% then stopped finding channels so the upper spectrum is blank.
        i had a downloaded channel package (likra) when first pluged the dm800 in and the signal dropped to 0 , but if we plug the dm500 back in it worked ok .
        I took the dm800 back home on my NON communal dish at it works a treat .
        so it must be the communal dish that is at fault.
        what do you think ?
        • rossi2000
          • 37
          cheers karl
          the inline amp i have is a 13\18db and it didnt make any difference
          ive just tested my original sky hd and that recieves all freeview hd so i assume it'll recieve the premium hd once activated.
          the signal on the sky hd box seemed quite low though, around 50% maybe abit under.
          i am now at a loss as to why the 2 x dm800s fail to work here.
          any ideas ?
          • karlpowell
            • 189
            the tuners in the dm.s are most likely a little less sensitive than the sky + boxes 505 is still not very good and you picture will be gone when it rains.
            looks like you will have to put up your own dish
            • rossi2000
              • 37
              i cannot put up my own dish unfortunatley, id of done that along time ago
              ive had breakup in the signal recently cos the weathers been bad.
              i am going to have to try a spiderbox or a vu+ solo one of them has gotta work.
