how do i link 2 receivers to 1 motorised dish
  • azza_stella
    • Jul 2010
    • 6
    Hi
    I have a tm6900 hd combo super+ and a dm500s.
    What I would like to do is control the dish from either receiver.
    I have read the forums about using the loop through or a switch.
    tried the loop through and the signal is degraded.
    not sure on what type of switch I would need and also which is compatible to both receivers.
    I am currently looking to upgrade my dm500s to another tm6900.
    Any guidance will be gratefully received.
  • nr24103
    • 26
    Originally posted by azza_stella
    Hi
    get a quad lnb
    • Adam_UK
      • 464
      he is using motorized dsih, using quad lnb won't help
      • andiewill
        • 490
        I think it will but only one box will control the motor, the rest will have to watch what the main box satellite is on.
        ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
        • Adam_UK
          • 464
          Yes that is what I ment, if he wants to watch 2 different channels not on same polarity at the same time then fixed LNB must be used.
          • alec
            • 345
            I use a twin LNB, with 2 cables going to 2 receivers. The main receiver controls the movement of the dish. Another cheaper way is use the loop through on the main receiver to another receiver. I don't know if you lose quality with this method, with both receivers on.
            • jojo1212
              • 125
              I think it will .one box is goin to control the motor
              the rest is going to watch what the main box satellite is at.
              • DNG2010
                • Mar 2010
                • 369
                You are correct, only 1 box will control the motor.
                DNG
                Due to a severe downturn in the economy the light at the end of the tunnel has been switched off until further notice.
                • satsid
                  • Aug 2009
                  • 815
                  I run 36 volts it's better.I know someone who runs 2 receivers on twin lnb,other way 2 move dish.He moves dish with a tm1500 & watches from other box (ie dream or receiver like that)
