a simple questiong about RG6 cable
  • mario123
    • 383
    1. ok iv been told i need rg6 cable for my 1m motor dish i was just wondering about the thickness of cable i need? does this affect the signal on the dreambox?
    RG6 is all the same thickness. Have a look here m8 RG-6 - Wikipedia, the free encyclopedia
    • mario123
      • 383
      ok thanks for m8 for pointing that out to me so is there any factors in the cable that can cause better or worst signal coz iv been looking at a few differnt sellers so one on fleabay doing it a pound a metre and a few companys i found on google products are doing it for as little as 30p per metre and 50p per metre.
      i guess wat im asking is there better made up cables or they all the same really?
      have a look below at the ones i was checking out and see wat any1 thinks pls?
      PULSAT.COM - SATELLITE COAX CABLE RG6 BLACK - SATELLITE TV LEADS & CABLES
      RG6 Screened Coax Cable - Brown per metre from Aerial Shack RG6 Double
      ANY LENGTH HIGH QUALITY RG6 Sat Aerial Cable Digi Coax on eBay (end time 24-Aug-10 18:28:46 BST)
        I bought this one 100m RG6 White Satellite Aerial Cable Sky Digital Coax on eBay (end time 29-Aug-10 19:21:45 BST) and use it with my 1m dish and 500 and 800 Dreamboxes. 100m roll for just a few quid
        also in black.
        • mario123
          • 383
          also in black.
          ....................ok cool
          • mario123
            • 383
            i brought this off ebay but i just noticed that external diameter is 6.3mm does that mean i wont be able to use a standard 7mm f connector?
            also i just noticed on my technomote motor instructions it tells me to use f connectors with a waterproff rubber sleeve on top or is that self a tape good enough?
            • mario123
              • 383
              sry for double post wrong link b4 100m RG6 White Satellite Aerial Cable Sky Digital Coax on eBay (end time 29-Aug-10 19:21:45 BST)
              • dick b
                • Jun 2009
                • 2462
                standard F-plugs will be fine by the time the braid is folded over they will screw on correctly, self amalgamating tape carefully used is also best make sure you cover the thread coming out of the motor and carry it down the f-plug past any strands of braid sticking out.Tm motors are usually supplied with rubber boots and you can use these as well providing your taping is neat.
                just to add some places sell f-plugs that are for shotgun cable as std plugs and they are not suitable for std co-ax.
                • mario123
                  • 383
                  yeah thanx for that i never got any them rubber boots with my tm motor is there anywhere i can get them now?
                  • mario123
                    • 383
                    yeah i just found the rubber boots in the box there. wat size of self amalgamating is best to seal it should i get the 19mm or 25mm one?
                    • alex123
                      • 832
                      rg6 is shit cable its used for analogue aerials you need ct100 fpr satellite and especially a motorised kit ,rg6 is the cheapest of cable ,even sky use webro 100 which is the same as ct100
                      alex
                      • mario123
                        • 383
                        alex
                        really y didnt any1 say i just bought 100m of that rg6 do i need to forget it and get ct100 then? and size of tape do i need the 19mm or 25mm to seal the f connotor?
                        • dick b
                          • Jun 2009
                          • 2462
                          rg6 is fine its all I"ve ever used and never had problems with it.Its double screened for satellite use the main difference between rg6 and the more expensive ones is the central core is copper coated steel and not solid copper.use the narrow self amalg tape just make sure you stretch it slightly as you wrap it round and give a good overlap.
                          • notluckyuk
                            • Apr 2010
                            • 187
                            totally agree with dick b, rg6 is fine..
                            • dave-h
                              • Apr 2010
                              • 659
                              Well i disagree.
                              Alex123 is correct, it's shit cable and not recommend for sat use...
                              Have a read of Bill Wrights cable comparison article HERE which outlines the differences between cables and why cheapo RG6 and the likes aren't recommended on sat installations.
