THIS IS FOR LAN 1214 BOX
DO NOT LOAD THIS FILE ON A NON LAN BOX OR IT WILL KILL YOUR BOX YOU HAVE BEEN WARNED !!!!!!
NON LAN BOX IS THE BOX THAT DOES NOT HAVE A RS232 CONNECTOR ON THE BACK OF THE UNIT THIS WAS THE FIRST BATCH OF 500 SOLD !!!!
Load grooverider file on to your usb memory stick,make sure power is off on machine and insert the memory stick into the front usb socket
underneath the front flap.
Turn the HD Combo on.
From the main menu go to Utility and then press the right arrow button and select usb
from the right hand side, you will see the grooverider file press ok on it and make sure to select SW+ALL DATA UPDATE..
the machine will update and restart (don't pull your memory stick out until the machine has fully started up)
you now need to scan your channels,
so go to installation press the right arrow button again and go down to AUTO CABLE SEARCH
all you need to change here is the symbol rate.
The symbol rate determines your area for example ntl is 6887, the other numbers are 6952 for telecast and EXc&w.
When you have selected your area go to start scan.
once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989"
you will then see "keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
Then go to to your channels by exiting the menu and pressing ok..
Select a non FTA channel and leave it until a picture appears
PLEASE NOTE IT CAN TAKE UPTO 5 MINUTES TO UPDATE
Channel list..
all your channels are categorised by
pressing ok on your remote brings up the channel list but it will be in simple layout,
pressing the red button takes you to detail,
now if your list don't appear to be categorised you will need to press the SAT button on the remote and you need to select cable
at the bottom of the list this will then give you the categories,
to change each section you simply use your left or right arrow buttons
GOOD LUCK
GrOOvErIDer
For the satellite side to go on network you need to go to Accessory then go to the right side on the menu to network.
Press OK on network then go to Type then you will see 4 more sections in the menu, go to Server setup and press OK You will see 10 different Servers
in there,
Go to off 1 and press ok, in the menu it will say off if you highlight OFF and go to the right on the remote you can pick CCCAM or NEWCAMD in the menu.
This is where you can setup your server needs here.
If you have a Config file (CCCAM or NEWCAMD) made up , put it on a Memory Stick then go to USB in Accssory and press OK.
At the bottom it will say Config highlighted by a Red button, if you press the Red button on the Remote it will give you 3 chorses,
pick Auto Detect then it will start to read your memory stick if you got your Config file on your stick it will then load your config file in here.
Now go back to Network and press OK then Server Setup you will then see all you Config details have now been loaded in your
Channel list..
GOOD LUCK
GrOOvErIDer
in there,
