set the right settings inLatitude: 54.5756? Longitude: -5.9278? tm2600 motor
  • mario123
    • 383
    ok guys im on
    Latitude
    : 54.5756?
    Longitude: -5.9278?
    on my motor i have both elevation and lattitude scale. what wud the rite settin be on this scale 55 and 35 on scales or 54 and 36?
  • firestorm
    • 1550
    the scale is not that accurate either will do but 55 and 36 are the closest. Just jet your dish pointing at true south turn slightly to the west(only 1 degree) put you box on bbc on 1w and move the elevation and lattitude on the dish till you get a good signal best to buy one of the cheap swinging arm meters like they have in maplins for about ?15.Then use the usals to try and follow other sat just tweaking it up and down till all the sats fall in
    • mario123
      • 383
      ok thanks man. coz im in belfast do i not have to use 5w intead of 1w for my ref sat?
      • mo.p
        • 298
        m8 try reading these two link. that should help u
        Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
