Q-Box Full version with Diablo
m8 the diablo was done by a hacking team duolabs came up with the idea and have the tools to build it also they have the stuff to hack a card after all they can make cards them selfs , hackers do the firmware its the same as the base unite they have and now the wifi cam all work done by hacking teams duolabs put the money up , look were all there support comes from for there stuff hackers as for buying keys this is a story that has been going about and no one is 100% sure about this after all they only make a cam they dont put key files on there site or relate to them in any way all work is done by hackers and forums , why the team i know of did not get the receivers is nothing to do with key files rick is as fly as they come and even with the base unit he pulled a move on the team that worked on it also the receiver has a diablo in it and they have worked on it already so why not the receiver from what i know they were asked to make the firmware loader , key files and images but it never came of lots of messing about went on thats all i can say .What I was realy trying to get at was Duolabs have been playing games with customers for years, As reported Duolabs went as far as buying Keys from certain providers and emulating them on there hardware, the reason why you might ask (an Indirect subscription) this provided extra supscription income for providers mainly in Spain.
This answers how Duolabs can open other Encryptions that have yet to be opened by other forms of hadware and software, also this could be why Duolabs would not hand over there receivers to be worked on by Hacking Teams because they buy what they need.
Also any one can open an encryption just look at what nds did to nagra and got away with it so why cant duolabs do it as long as they dont pass it on we can only wait and see what come's of itComment
from to-day the conax channels on thor 1w, eurobird 9e, and astra 19e
are down to-day on the diablo cam digialb and the chns on 8w
are still open so it looks like a new underworld file is neededPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
Duolabs released a new Update today should fix it, if not a totaly new patch will be required.
Fix for last Underground Patch.
(UnderWorld147) NEW (La7 fixed) DATA.BIN (renamed) + S2 TABLES (S2_NL.BIN missing in last firmware)Last edited by alunfennell; 25 November, 2008, 12:45.Comment
enigma 1 only supports one tuner. for the Qbox, it is a satellite tuner. the Qbox switches between the 2 tuners automatically. So, if you want to manual scan on 218Mhz you have tune to 12218 Mhz and set the symbol rate 800 to let to STB know that it's a terrestrial transponder.
This works great UNLESS you have a motorised setup because the terrrestrial
channels are associated with a satellite. The qbox tries to move the satellite dish when you switch to a terrestrial channel from a channel on a different satellie.
I havent tried any cardsharing, but AFAIK ,the Qbox has a piece of hardware
that can delay the video stream by a few seconds. Which I think is for cardsharingComment
underworld 148 26/11/08
Underworld 148 26/11/08
New Diablo Cam UnderWorld 1.48
i'm told the premiere conax chns are not open with this file
and a new data bin will be required to open these channels
^^^ Working on: ^^^
^^^ ? Diablo CAM Light 2.2 /2.3 ^^^
^^^ ? Diablo CAM Wireless 2.2 /2.3 ^^^
^^^ ? Diablo CAM Wi-Fi 2.3 ^^^
What's New??
Emulators fixed:
DigitAlb-Sex View-FreeX-Canaal Digital Nordic
XclusiVe E M Us
?All Vers.? Irdeto2: Free X TV - Hotbird 6/7A/8 (13?E)
?All Vers.? Irdeto2: LA7 - Atlantic Bird 1 (12.5?W)
?Version 2.3 ONLY? Irdeto2: Sex View - Hotbird 6/7A/8 (13?E)
?Version 2.3 ONLY? Conax: Kabelkiosk - Atlantic Bird 2/Telecom 2D (8?W)
?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 (0.8?W)
?Version 2.3 ONLY? Conax: DigitAlb - Eutelsat W2 (16.0E)Last edited by benny/9; 18 December, 2008, 16:11.Please Read Carefully!
Benny/9 you are moving around a bit ? finding yourself a new home with us ! hope you stick around your a knowledgeable guy.
Kind Regards:Comment
Diablo
Thanks for the files.
Man there is lots to read. AU on/off PMT....Slowly getting through all the info. Do you now if there is a clear cut definition in one place where I can truely master the Diablo card. I still have only the card 2.3. and the CAS 3 programmer, no card inserted, cant find out what the cards do.... If anyone can help please let me know. In the meantime I will keep on reading tp try to become an enlightend one...Comment
************************************************** ****Thanks for the files.
if you are asking about the green palastic dummy cards
and ribbon cable you got with the cas3 programmer they
are for use programming various different cams. and are
not used to program the diablo cam.Please Read Carefully!
