Help please !
  • Tez2010
    • 85
    Help please !
    ive got a technomate 5400, got a strong signal on 1w- 28.2, but nothing further east. also wen i drive my dish to 13e, i pick up a good signal, and pick up a couple of strong signals on 16e (when im on 13e) but when i drive my dish to 16e i cant get a signal on any transponders.. is this an allignment issue, gutted i cant recieve 39e for football. or cant get any signal on the transponder that tring operates on 16e. missing football left right and centre ! im in north wales 90cm dish (mesh) thanks
  • dick b
    • Jun 2009
    • 2462
    yeah it does sound like an alignment issue and 16E does need to be spot on to get a good result try this setup guide for std TMs.if you dont want to use 1W as the target sat use 5W as it may be nearer due south for you 11.591V 20000 is a good TP with the french ARTE channel on it to help you setup
    • Tez2010
      • 85
      so would you reccomend starting from scratch ! would i have to do a factory reset on my reciever to now set up from 5w? cheers !
