conflicting satellite handles
  • johnwilliam1
    • 55
    hi guys,
    i want to mention that recently i bought a spiderbox 9000 but the trouble started when i switched on my tecknomate 5400 and what happened was the spiderbox 9000 that came on as well, i tried the tek 1500 handle and that also started the spiderbox, so guys be careful if you are going to buy a spiderbox 9000 that if you use tecknomates 5400, 1500 and around that range. The teck 6800 is ok, thats not a problem.
  • dave-h
    • Apr 2010
    • 659
    What does conflicting satellite handles mean? Do you mean remote contol conflict?
    • johnwilliam1
      • 55
      sorry yes, thats what i meant
      • firestorm
        • 1550
        i had this with a tm1500 and a starview1 used to block of the front of the box i was not using at the time
        • wooper
          • 460
          I have 3 sat boxes, 2 cable boxes, blu ray player, surround sound. And tv!!!
          Found it usefull to have those multipull plug jobbies that have the on/off switch on each socket, if that makes sense.
          More remotes than soft mick.
          • johnwilliam1
            • 55
            yes, at the moment the spiderbox is on and the teck5400 is switched off, but i have thought and tried putting a piece of cardboard in front of the panel of the spiderbox.
