3 inch L shaped bracket
  • jpr
    • Jun 2009
    • 161
    Does anyone know where i can get a 3inch L shaped bracket for a 96cm channel master.
    I have seen plenty of these brackets on 96cm channel masters that are used for broadband.
    I had the dish on a 3 inch pole in the ground but need to move to the side of the house and only option is up on the wall.
  • Bluezola
    • Mar 2010
    • 11
    3 inch l shaped bracket
    Go & have a look in B&Q's or wickes,they're sure to have it or something you can adapt,have a look at the shelf brackets or go & have a look in the garden fence sections .Make sure you try get something that is galvanised or zinc plated ,this will stop the rust corrosion.If all that fails go & ask them for a galvanised roof strap about 1" wide & about 3 foot long ,this has a series of holes already drilled out,they are already L shaped ,you may need to cut it to length but it will support the dish easily,they're used for holding large roof joists in place then get plastered over.
