hi i have a labgear 60cm fixed dish and box, but want to upgrade with a motor, if i bought a technomate (for example) motor would this fit on my dish, what i am trying to say are there universal motors, and are they easy to set up, cheers all.
satelitte motor
Tags: None
Satellite motor
There is no reason to suppose you cannot motorise your 60cm dish with a diseqc motor ~ however it would be worthwhile getting a bigger dish at the same time, around 80cm if you are in the south UK and 90cm for Scotland and north UK. Attached is a picture of a Diseqc motor & 90cm dish for your info.
There is also my Diseqc motor setup tut in the DK downloads section sat sectionAttached Files -
You must set the Dish on True south, 1 degree west should suffice. Go to a Free to Air channel , when you have the best signal lock your dish to that. You the then will be able to view the satellites 42e to 30 west. If you know anyone who has a signal meter would be a help.Good Luck but you should not need it.Comment
