motorised or monoblock
  • standarren
    • 857
    hi guys i'm just in the process of getting together everything i need for a resonable satelite system
    i'm pretty good with the cable dbox so would think a box thats linux based is best for me
    so bearing that in mind what would you guys reccomend a motorised dish or a monobloc lnb
  • dave-h
    • Apr 2010
    • 659
    Depends what you want, but they don't really compare.
    A decent,well setup motorised dish should be able to receive channels from 20+ sats, with a monobloc LNB you're limiting yourself to 2 sats.
    Unless you mean a multi-sat/LNB set-up?
    • utdman
      • 183
      motorised all the way...
      • standarren
        • 857
        would this be any good its on ebay item number 230518398256
        • standarren
          • 857
          oh no what have i done wrong everyones ignoring me
          • dick b
            • Jun 2009
            • 2462
            that number is meaningless get yourself a TM 2300 orTM 2600 most sat dealers stock them or get direct from Technomate I dont like e/bay so dont use them.
            • standarren
              • 857
              sorry dick have alook at this link
              eBay - The UK's Online Marketplace
              • opsmonkey
                • 5379
                jesus its rusted to ~~~~..
                You can get a 1m dish for ?40 and motor for ?40.. all brand new..
                if your buying 2nd hand its a risky do..
                • standarren
                  • 857
                  ok guys i need a cheap system to get me started really dont cars if it looks tatty as long a its cheap so can you guys check the dish out on ebay
                  one more thing how do i tell if its a digital dish with lnb or analogue
                  • ITS A SCAM !
                    • Oct 2008
                    • 1140
                    Try here.......This is a 80cm motorised dish with a TM2300 motor ( all fixings etc supplied as well ) for ?99
                    80 CM MOTORISED DISH PACK SOLID - ?99.00 : Wizard Satellite, Satellite receivers, dishes, lnbs and equipment
                    • standarren
                      • 857
                      thanks monkey but if thats the worsed thing about it the rust i wouldnt mind because after i finished with it it would be spot on mate would that be ok though is it digital
                      come on what do you want for a tenner
                      • dick b
                        • Jun 2009
                        • 2462
                        it just aint worth using 2nd hand mate its going to take a lot of effort to get the motor and dish up and then correctly aligned.if the dish is rusty it must be ancient it takes years to get like that.
                        • dave-h
                          • Apr 2010
                          • 659
                          That dish is ancient, and also a polarmount with a linear actuator, so unless it's been supplied with a v-box to control/power the motor (linear actuator) its not much use with modern DiSeqC receivers.
                          If you need to buy a V-box that will cost ?40+ and looking at the condition of it i'd be surprised if it's in working order and depending on the length of the actuator that will be another ?40+ to replace.
                          In short, you'd be better off ditching it, and going for a new dish and DiSEqC motor.
                          • standarren
                            • 857
                            thanks mate
