i brought a vu+duo on 21st june 2010 but now iam having problems with it , the unit wont flash image via usb & if i flash image via rs232(lan) it works but when you restart the reciever it just says STARTING all the time and wont boot into the system just hangs on starting all the time i have to turn it on & off at the plug about 4 or 5 times to get it to boot what can you do
BIG Problem with my vu+ duo
thats the thing with the VU,, a cracking reciever but no ware near the same support as the dream,,,i brought a vu+duo on 21st june 2010 but now iam having problems with it , the unit wont flash image via usb & if i flash image via rs232(lan) it works but when you restart the reciever it just says STARTING all the time and wont boot into the system just hangs on starting all the time i have to turn it on & off at the plug about 4 or 5 times to get it to boot what can you doFaster than Faster
vu fix
hi, I too had this problem and my supplier came up with this fix using serial cable.
Switch the box off, on the rear side.
choose in putty for serial connect, speed must be set to 115200 and choose you`re comport.
Put the box on, when you`re connection is oke, you wil see some text scrolling over the putty screen.
Now use the ctrl + c key to stop the booting.
copy the following line in the screen:
boot -z -elf flash0.kernel: 'rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
The box now reboot from the flash, so watch you`re box.
Then open telnet with dcc and put in the following line.
flash_eraseall /dev/mtd5
and after that the following line
reboot -f
Then you`re box is running again.Comment
Has your box is still new, you could ask at the official site.
Vu+ Portal : The Official Web Site of Vu+. The inquiry site Vu+ Portal : ContactsComment
reboot -f
hi im interestiti on buying vu+ dou, but non of the supplies provides support or warranty if you change image, can you please tell me you supplies i will buy from himComment
Hihi, I too had this problem and my supplier came up with this fix using serial cable.
reboot -f
I Do it this STEPS but no thing Change
Take Look at Log
Code:BCM73350010 012 Shmoo Version=1.9 MEMC-00000000 RW=00000011 WW=00000043 G=00000001 R=00000008 W=00000013 MEMC-00000001 RW=0000000F WW=00000053 G=00000001 R=00000008 W=00000007 #$ 3 COPY CODE A567 BCM97335B0 CFE v2.17, CFE core v2.12, Endian Mode: Little Build Date: Wed Dec 9 17:23:18 2009 (shcheong@ncsh) Copyright (C) Broadcom Corporation. writing vfd DDR Freq: 395MHz CPU speed: 405MHz Memory Config: 32+16 non-UMA Device Tech: 1Gb Total memory: 384MB Boot Device: NAND ECC: Hamming Total flash: 128MB Initializing USB. USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub CFE initialized. checking usb Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3 Loading: Failed. Could not load : I/O error CFE>
After exu. command
guys i think command is wrongCFE> boot -z -elf flash0.kernel: 'rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
Loading: Failed.
*** command status = -4
CFE>help boot
SUMMARY
Load an execu file into memoryexecute it
U
boot [-op] host:filename|ilename
This command land executes a pr from a boot devi By default, ' will load a rawry at virtual
address 0x20000nd then jump to address
OPTIONS
-elf Load the file as an ELF executable
-srec Load the file as ASCII S-records
-raw Load the file as a raw binary
-z Load compessed file
-loader=* Specify CFE loader name
-tftp Load the file using the TFTP protocol
-fatfs Load the file from a FAT file system
-rawfs Load the file from an unformatted file system
-fs=* Specify CFE file system name
-max=* Specify the maximum number of bytes to load (raw only)
-addr=* Specify the load address (hex) (raw only)
-noclose Don't close network link before executing program
*** command status = 0Comment
But what would you prefer.
I near 100% reliable box with less support, or a box with so much support because it is so unreliable? LOL...
(not having a dig, but you get what i mean!)Comment
