Few questions
  • dan20leeds
    • 168
    Few questions
    I am looking for the cheapest hd box compatible with cs?! Second what is the difference between a clone and a normal box? Also any way to watch dreambox in two rooms?
  • the man
    • 1660
    cheapest may not be the best easyest box to start with, you can watch a box in each room if you have sat feed to both rooms,
    id say get a dm 500 sd just to start with then upgrade to 800hd when you know how the boxs work!
    • hypersonic
      • 254
      Few Questions
      Dan m8
      If you are just starting in satellite after migrating from cable go for an SD receiver as The Man has recommended until you know how it works ~ The TM500 or 600 are also a bargain at under ?100. A motorised system would give you the most satellites, although you need a clear view south & also, east and west of south to get the full bouquet of available satellites ~ Go for a 90cm dish with a diseqc motor. You can move on to HD once you have set up your dish & SD system.
      • iMAGiNE
        • 37
        Ive seen on ebay a box called Openbox, it's a HD satellite reciever and costs about ?120, thinking about getting myself one once i have the money.
        • citygent1911
          • Jun 2009
          • 94
          Just received mine iMAGINE, good solid bit of kit.
          Only got my dish up tonight, so still to align it with Astra, so no doubt I'll be around on the forum if you want to keep any eye out for posts!
          There's a few people around with these boxes - they also use the name skybox s9 and solomend s9, but they're all the same apparently. Swanside, irfy, and data7 are all familiar with them.....
          hth...
