monobloc Lnb Diseqc settings
  • steviep5
    • 5
    Hi all . hope somebody can help
    I have been helping a friend put a monobloc on his dish (13E and 19.2E)he originally just had 13E everythings gone well until we had to change the diseqc settings (being new to this we both have no idea ) in the settings I have found diseqc 1 to 4 and diseqc committed or uncommited I have put 13E at 1 and 19.2 at 2 but no idea about the other commited or uncommited I think I have tried both but my friends just rang to tell me he has half the 13E channels missing now . does any body understand and can tell me what the settings should be . Thanks
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    If he only receives half the channels may i ask, are they on the same polarity?ie horizontal, or vertical. If its just one of the polarities, chances are that the monobloc isnt universal.. Or the prob could be fine alignment needed!
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • steviep5
      • 5
      Don,t know Ill check polarity today its supposed to be universal lnb . but what do the diseqc settings actually mean . (committed /uncommitted)
      • .: JaCkPoT :.
        • 5607
        no idea waht (commiteed/uncommited) is... what receiver are you using????
        ___________________
        DM800s HD
        Openbox S10
        TM500
        DM500s
        Maxx 110cm Dish
        • steviep5
          • 5
          A Force receiver not sure what number but think its a series 5
          • benny/9
            • 1964
            to set a monoblock lnb up for astra 19e and hotbird 13e
            put the right hand horn of the monoblock lnb in the holder on the dish
            and set the dish on horbird 13e as the prime target, in the diseqc motor settings you will see [diseqc 1.0] and [diseqc 1.1] use diseqc 1.0 in this
            section you will see 1 2 3 4 or A B C D use ie: [1] for hotbird13e and get
            a good signal then scan the satellite and check the channels are all open
            horizontal and vertical frequencies with a good signal, to get astra 19e
            you must set the left hand horn of the monoblock lnb slightlt higher than
            the horn in the dish mount for hotbird 13e and set the diseqc 1.0 settings
            to [2] and ajust the monoblock for a strong signal then tighten the mount
            bolts and scan astra 19e and again check the channels open with a good signal, now double check hotbird for a good signal by changing the diseqc 1.0
            back to [1] if both satellites have a good strong signal the jobs done
            to change satellites you go into the motor settings and change between
            diseqc 1.0 setting>>> [1] to [2]
            Please Read Carefully!
            • steviep5
              • 5
              thanks its all set up now and everything working . reset receiver and it asked for positions just put 13E on 1 and 19.2E on 2 as said in the last reply and it worked although the reason he had lost some channels last night we hadn't acctivated his packages.
              So now we have added 9E on a separate dish via a A/B switch but the signal is low so not good quality .Would this be to do with the dish being a sky 55cm (zone 2 ?).?
              Would changing the Sky Lnb for a better quality one make any difference don't really want to swap dish .
              • benny/9
                • 1964
                hi m8,
                a dish that size is only for use on astra 28e even though in good weather you will get signals from the stronger satellite's for eurobird 9e you need a dish of at least 90cm in size.here's a list of dish sizes
                this could help anyone setting up a dish in
                the u k this gives you dish sizes required
                for the satellites from east to west
                75 east 90cm
                72 east 60cm
                70.5 east 90cm
                68.5 east 100cm
                62 east 60cm
                57 east 60cm
                53 east 60cm [120cm required for 12500 to 12750 beam]
                45 east 60 cm
                42 east 75cm [ some transponders require a larger dish]
                40 east 80cm
                39e ----- 60cm
                36e ----- 80cm
                33e ---- 90cm
                28.2e --- 45cm
                26e ----- 90cm
                23.5e --80cm [most tp's require a larger dish from the uk and a HD receiver]
                21.6e -- 120cm
                19.2e ---50cm
                16e -----90cm [ some transponders could require a larger dish]
                13e -----50cm
                10e -----90cm
                9e------90cm
                7e ------80cm
                5e ------90cm
                0.8 west 90cm
                1 west -60cm
                4 west -100cm
                5 west -60cm
                7w ------120cm [ the H transponders require a very large dish from the uk]
                8w ------50cm
                11w -----135cm
                12.5w ---60cm
                15w -----60cm
                18w -----60cm
                22w -----90cm
                24.5w ---60cm
                27.5w ---60cm
                30w -----80cm
                31.5w ---80cm
                34.5w ---80cm
                43.1w ---60cm
                45.1w ---60cm
                58w -----90cm
                This is only a guide not all transponder's will be received if you are outside the intended coverage foot print of a satellite,
                a lot of satellites can now be picked up with a 60cm & 0.2 Lnb.
                • daddysnow
                  • Sep 2011
                  Thanks chap, this info will help me out too.
