hi chaps i'm having difficulty trying to get certain channels on arabsat 26.0e i have a motorised 90 cm dish with tecnomate 5400 i'm only picking up 48 channels any suggestions would be gratfull
hepl trying to get arabsat 26.0e
Tags: None
"a 3 meter dish", only joking m8! only the channels from badr4 are available in the uk with a normal dish and 90cm is a little small. i get around 200 channels using a 1.1m triax but you could try fine tuning your set-up a bit to see if it helps. look for channels between 11.900 mhz and 12.300mhz and the txp@ 12.525h. 27500 as this should be recievable also. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
