What is the best 80cm Sat Dish ?
  • steb71
    • 28
    Hi All,
    I am looking at buying a 80cm Dish for mu TM 6900HD Combo setup.
    Can anyone tell me the best one to buy and also where is the best place to buy.
    Cheers !
  • 00360362878
    • Mar 2010
    • 488
    Just have a browse through fleebay steb, you should get one for arround ?50. Or you can go for a motorised dish. I got a 95cm dish with tm2300 motor ?100. Obviously you will have your fixing costs, unless you can do it yourself. Can be very frustrating!!!!!!! there is plenty of info on here howto.
    good luck
    • ITS A SCAM !
      • Oct 2008
      • 1140
      I have asked for a price on a " Fine tune " of my dish...He wanted ?70 ish. I shall buy a half decent meter and do it myself for that. I also got myself a 85cm motorised dish kit ( from wizard satellites ) for just over ?100, this included a TM2300 motor and Technomate LNB...Also included was a 20mtr roll of Coax, F plugs etc. Its still worth buying a decent set of T & K brackets to use instead of the supplied bracket. So this will add about another ?10-?15 to the price
      • 00360362878
        • Mar 2010
        • 488
        Yes mate same with me, mine still needs tweeking, just got back from holiday to this great uk weather so messing about on ladders is postponed, but I am confidant I can do it as I bought the meter shown in the link below from fleebay. I had a mess about with it before I went away, its pretty easy to use and you know you are on the right sat as it has all the sats plumbed in and all you need to do is input your long lat and its ready to go. I have used a mates Horrizon and in my opinion the pro digital is by far a better machine. Also you dont get a customs charge as they send as a gift.
        PRO Digital Satellite Finder Signal Meter Measurer MF19 on eBay (end time 03-Oct-10 19:20:39 BST)
        • thijs
          • Apr 2010
          • 1096
          Originally posted by steb71
          Hi All,
          Cheers !
          are you going for fixed or motorrised triax with a multi bracket is
          working very good for me with four quad lnb's on it .i have no good spot for motorised
          Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
            fair expensive bit of kit mate yad want to be getting a good bit of use with it
            • 00360362878
              • Mar 2010
              • 488
              True. But you pay less than that, all you get is peepin an whistlin. Trouble is that could just be because you found the O2 mobile phone mast, or a mobile speed camera.
              It is a good bit of kit though.
              • mapex
                • Jul 2010
                • 209
                penta 85cm......check it out
                • pooface
                  As mapex said, the pentax is a good dish... Also, the gibertini 85cm is a good dish as well. When using a decent lnb (such as the inverto black ultra)...
