Anyone have the triax multi lnb?
  • Pittsey
    • 33
    I have lost the manual for mine and need to know how far 19.2e should be from the centre of the bracket.
    So if anyone has the manual, I could really do with some help.
    Thanks in advance.
  • thijs
    • Apr 2010
    • 1096
    I have the triax multi bracket with four quad lnb's
    one for hotbird 13 east one for astra 1 19.2 east and
    astra 1d3a 23.5 east and astra 2 28.2 east looking on the dish
    i have astra 19.2 as cllose to the middle as possible on the right
    side
    and then moved the dish untill i had signal . locked the dish then
    put lnb for hotbird 13 on the right side move the bracket or lnb down for hotbird then i put lnb astra 1d3a 23.5 on the left of bracket as close to the middle as possible and then i put on lnb for astra 28.2 on left of bracket and had to move lnb bracket or lnb up very high to get good signal
    never looked at the manual i have it somewhere in the attic if you realy want it.
    Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
    • Pittsey
      • 33
      Thanks for this. This will help, Cheers.
      • dctyper
        • 2539
        SatLex Digital :: Technology :: Calculators :: WF Toroidal Calculator
