Urgent help needed
  • nagasaki1
    • Oct 2010
    • 11
    Urgent help needed
    Hi
    Have purchased a spiderbox 9000 but need help to install
    have conected to router but how do i know network is correct?
    i cant get it to find any satellites but had no problem with my technomate, do i need to setup longitude and lat etc
  • dick b
    • Jun 2009
    • 2462
    yes you have to set up long/lat go to installation>motor setup,press green button to edit your local position. have you installed the latest 9000HD patch from the support forum of the place where you bought the box from?they will also have all the info on set up you need.if you have installed patch go to accessory menu>network type 1111 to open hidden menu scoll down to service+ to register and turn on.nuevoxstream is not active on latest boxes.
    • nagasaki1
      • Oct 2010
      • 11
      i believe the gift was added
      i can get all the satellites but all channels are saying scrambled.
      • the man
        • 1660
        whys it Urgent?
        you will be better on going on the spiderbox forums
        google alsat forums
        • dick b
          • Jun 2009
          • 2462
          if you bought the box new gift will not have been installed.
