sat switch
  • evens
    • 59
    sat switch
    got motorised set up is it possible to have another fixed dish and use a sat switch.
  • wilf
    • 1618
    do you mean a disecq switch? that was the purpose of a motorised setup so as you dont have to have multi lnb and disecq, but i dont know think the reciever will be able to do it because you will have set it up for usals, but then again i dont have a twin tuner box maybe they are different set up for each tuner
    • patkins
      • 3662
      You dont give much information about your set up or what you are trying to do which, like wilf, leaves me confused.
      The short answer to your question is yes if you, like wilf suggests, use a two way diseqc switch.
      If you want both receivers on the motorized set up you can use the lnb out facility on your present receiver cabled to your lnb in on the second receiver.
