I'm looking to buy a DM600 pvr and I need all the other bits aswell like dish pole cabling and all that.What card and cams I need,if any as i'm going to card share,just wanted to know what I really need for a complete system and cost,as this is the road i'm going.All help appreciated thanks
Costs
Tags: None
It really depends on what sort of dish set up you are looking for. Would you prefer a 80cm or 100cm? Fixed motorised or multiple LNBs?
If I were you I would have a look at Ebay or your local satellite store and buy a satellite kit instead of buying things seperatly as this would be a cheaper way of doing it. But if money is no problem you could hand pick every thing from the best LNB, to the best satellite brand to the best motor its really up to you. -
Nothing to cheap and nothing to expensive,just want something to start watching the footy and i'm going for the cardshare option aswell.Thanks for replyingIt really depends on what sort of dish set up you are looking for. Would you prefer a 80cm or 100cm? Fixed motorised or multiple LNBs?
If I were you I would have a look at Ebay or your local satellite store and buy a satellite kit instead of buying things seperatly as this would be a cheaper way of doing it. But if money is no problem you could hand pick every thing from the best LNB, to the best satellite brand to the best motor its really up to you.Comment
Heres a few Ebay links to satellite kits
80cm
Satgear 80cm Anthracite Satellite Dish Kit & Satfinder on eBay (end time 30-Oct-10 20:50:08 BST)
Satgear 80cm Motorised Satellite Dish Kit - Off-White on eBay (end time 04-Nov-10 15:05:40 GMT)
100cm
1m MOTORISED SATELLITE DISH DiSEqC 1.2 MOTOR + 0.2 LNB on eBay (end time 26-Nov-10 17:19:04 GMT)
1m SATELLITE Hi-GAIN DISH & TITANIUM 0.1dB LNB 100 CM on eBay (end time 31-Oct-10 02:40:52 GMT)
120cm
1.2m MOTORISED SATELLITE DISH DiSEqC 1.2 MOTOR 0.1 LNB on eBay (end time 07-Nov-10 18:06:00 GMT)Comment
So any of the above will be sufficient for the DM 600,obviously some are better than othersHeres a few Ebay links to satellite kits
80cm
100cm
120cm
