I have a new receiver that is not compatible with my old Nokia SatScan motor. I have decided to put 3 LNB's on my dish pointing to Hotbird 13, Astra 19.2 and 28.2. Currently my oval shaped 90 cm Triax dish is still mounted on the motor shaft and slightly leaning from the vertical. The two questions I have are these:
1. Will this oval shaped dish be suitable?
2. I do not believe there is any vertical adjustment on the dish. In case I take it of the motor and put it on a vertical pole it will be dead straight. Would this be OK or should I leave the dish on the motor shaft?
Many thanks
Many thanks
