Channel Reception On One Meter Dish
  • tooloud
    • Mar 2010
    • 25
    I have a dm 800 hd box with a motorised 1 meter dish I am using latest pli open source image.
    My problem is that I cannot pick up thor @ 1% west
    I can pick up the larger satellites but seem to have a problem with minor ones.
    I have maged to pick up badr @ 26% E but for some reason i am only getting about 50% of the available feeds.
    I am particularly interest in getting the sport channels on this satellite but i cannot pick them up.
    I have downloaded the sat files from http://satellites-xml.eu/ so i should have the relevant setting etc.
    Can anyone suggest a reason why this is happening or even better a solution to this problem.
    I THANK YOU ALL IN ANTICIPATION OF YOUR HELP
  • Manic01
    • 5117
    Whats your location?
    • Adam_UK
      • 464
      You can only get Badr4 out of 26E with 1 m dish if you are in UK, you can't get Badr6 which has AD sports channels
      • satsid
        • Aug 2009
        • 815
        If your in the uk & no 1 west,your dish needs a re-line mate.
        • mario123
          • 383
          u should get 1west no probs did u not use this to set ur dish up as ur ref sat?
          • hugjam
            • Mar 2009
            • 46
            i have the same setup and have no problem with thor or badr.however i use a tm 6900 as i seem to receive more channels than with dm800.also you may need to fine tune your dish.good luck.
            • southpaw
              • 2233
              I think that site doesn't have 1w in its database. Try downloading your settings elsewhere matte
              • opsmonkey
                • 5379
                I use that site regularly and can 100% confirm it DOES have 1w
                • southpaw
                  • 2233
                  it has 0.8w but not 1w , try loading a settings file from addons , and you will get more channels on the 1w+0.8 sats
                  , i had this issue in past with that xml generater site mate ,
