I have been having few problems with the reception in 16e and thought I would do scan to make sure all was fine. When trying to do the scan I couldn't find the sat in the list. I copied across a new satellite.xml file but still got the same. Why?
Digitalb 16 East
Tags: None
here bud try mine..
have you done all the good stuff.. rebooted the box / enignma etc..??Attached Files
Copied your file to etc/tuxbox but I am still not seeing it in the scan list. I am begining to wonder if it has anything to do with the new Pli image I installed recently on the dm600. if i look at doing a manual scan I notice there is 15.8E & 17E so maybe thats my problem.Last edited by Curious123; 19 November, 2010, 18:01.Comment
I think 16e is now at 15.8 but haven't been on it in a while.Copied your file to etc/tuxbox but I am still not seeing it in the scan list. I am begining to wonder if it has anything to do with the new Pli image I installed recently on the dm600. if i look at doing a manual scan I notice there is 15.8E & 17E so maybe thats my problem.Comment
Haven't 16E been having problems with the satellites recently? I think they had loss of signal a while back and the new satellite that was meant to launch into that position failed to deploy. My signal from there has been pretty rubbish for the last few months and thats using a 95cm dish on the south coast.Comment
Gone back to Pli Jade 3 image and then checked again and it listed. I think it is similar to the problem I once had with 28.2E and 28.4E i.e if I go into Transponder Edit and edit the setting from 160 to 158 it probably fix the problem.Comment
HELP WITH 16E
Hi guys i need sum help on 16 e iwas working fine about 3 months ago but since last month it gone all i get it motor tunrning to 16e??
i have a 90cm dish motorised in west yorkshire?
using dm600 with darkman image
how do i get to 15.8
thnx in advanceComment
16 east problem
Hi max
I think that either your dish has moved slightly or the channels you are selecting on 16e are no longer being transmitted. Instead of selecting a channel go to 16e using your positioner manually & then select different transponders to see if you can get a signal. Then fine tune by moving the dish east & weat for the strongest signal quality, then save. If this works then you may need to fine tune all your sat positions again. If this does not work then it could mean the vertical alignment of the dish is out, however, this would affect the signal on nearly all your satellites.Comment
hey curious im having the samilar probs with mine for 4.8e 1w and 28e.
m using Nabilo Darkstar 2 as i read this may be a common fault on it.
but im only pick up about half the channels on these 3 sats getting switch service could not be found even tho i have signal. i treid the transponder edit but it didnt sort it ?Comment
You need to go to the Dreambox section of DK for advice on manual dish operation. I have a TM600 and manual operation of the dish is through the TM box menu ~ Have a browse through your DM manual, it should help you with this !Comment
I might be wrong but I think what you will find is that 4.8E is 5.0E and 1w is .08W and 28.2 is 28.4E. I know there is an easier method then this but I can't quite remember after a few drinks.hey curious im having the samilar probs with mine for 4.8e 1w and 28e.
Try doing Setup > sat & transponders > Transponder edit > 28.e > ok > change 282 > 284 orvice versa. You could also try copying the file posted by Opsmonkey called satellite.xml to etc/tuxbox.
