Sky UK EPG on Nabilo Blackhole E2
  • larsesp1
    • Dec 2010
    Anyone knows how to get EPG for Sky UK on the Nabilo Blackhole image (E2) (Dm8000)??
    Thanks in advance!
  • HoTTDubbER
    • 778
    Thanks in advance!
    it depends what version your using the older versions , if its an older one set up where you want to save the epg to zap ect
    then hit the radio button on your remote and go to radio station hiphop or EPG background music a box will appear saying found epg data stream let it update then hit tv find a channel press 2 for single epg and you should have a list of everything on that channel
    if you want it layed out like sky guide you need to store that channel to bouquet then hit multi epg and you will see all your saved channels layed out in a table
    use the serach on site mate you will probably find some guides for the version you have knocking about
    the newer versions 11 and on i think it is you can download the epg off the net but due to my Bootloader i use a patched v10
    so can only advice with the old method hope this helps
    Qualified Jedi Master
    Virgin VBox
    x2 PS3 JB FW 3.55
    X2 Wii 4.2E soft modded
    4x DM500S + JADE PLI
    Openbox HD S9 & S10
    DM800 PVR + BLACKHOLE
    Dedicated Linux Debian Server
    1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
    90cm Fortec Star Motorized Dish
    Virgin 50mb Fibre Optic Broadband
    Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
    Microsoft Approved and Certified OEM System Builder
    Subaru Impreza GB270 Owner
    http://online-console.com
    • dctyper
      • 2539
      welcome to the forum
      blue button then blue again then nabilo epg(second one dow)
      select your epg then yellow to download
      dc
      • HoTTDubbER
        • 778
        Thanks in advance!
        it depends what version your using, if its an older one set up where you want to save the epg to zap ect
        use the site search mate you will probbably find some guide for the version you have knocking about
        Virgin VBox
        x2 PS3 JB FW 3.55
        Openbox HD S9 & S10
        • nassa
          • Dec 2010
          rytec is probably the best source
          • opsmonkey
            • 5379
            why is this in the sport section..??
            did anyone ask for it to be moved..??
