multi lnb setup
  • paddybongo
    • 49
    multi lnb setup
    Can anyone help with this please,i had to reflash my DM500S and need to load the satelites,i have a 80cm dish with 3lnbs,28.2 19.2 13.2 but cant rember order they go,please if any help.
  • dave-h
    • Apr 2010
    • 659
    You assign them in the order they are connected to the DiSEqC switch.
    • paddybongo
      • 49
      sorry i dont under stand,when the sat guy set it up he told me the order they should go 19.2 on lnb 1 etc etc i cant rember there order
      • dctyper
        • 2539
        doesnt matter what order there in on the switch
        Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
        previous life dm800hd and 500c on cable screw you nag3
          I don't know much about the DM500 at all. However you need to look out at your dish. As you look from the front, which LNB goes into which port on the switch? Once you have that it makes setting up the DM500 a lot easier. Chances are 28e will be on port 1, 19 on port 2 etc. Until you find that out you can't set up the staellites on your DM500, since it probably needs to know which satellite is on which port.
          Try find that out first.
          • patkins
            • 3662
            or you could put 19e as no.2 and if the channels show then 19e is 2 or if not try one of the others as 2
            • Adam_UK
              • 464
              I had similar problem in setting my brother's box few months ago and used trial and error as Pat ssuggested and it will take little time to sort as you have 3 lnbs only.
