No BBC Three !!
  • acestu
    • 269
    No BBC Three !!
    Hi, could somebody please help me get bbc three, on a search it dosent find it and tried numerous times, i have a starview combo hd with the dish pointing at astra 2a, do i have to try tuning in after 7pm?
    Any info appreciated
    Cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • sob1467
    • Feb 2010
    • 604
    I think there is a new frequency for BBC Three. Search for the following 10773 H 22000. Scan it and if it does not appear delete the tp and re-enter it.Input the frequency 10773 H 22000 into your box and search it. Then you should be able to get BBC 3.
    • themanfromuncle
      • 24
      Isn't it also shared with CBBC or Cbeebies ? Could come up as that name then.
      • patkins
        • 3662
        Yes, if you look for BBC 3 in daytime you get the kids channels. I was fooled by this before almost to the point of distraction when trying to get it for a mate.
        • acestu
          • 269
          NO JOY !!
          Hi Fellas,
          I have the cbbc and cbeebies channels already but no sign of bbc 3 any other advice welcome....
          Acestu
          • Grizz
            • 1598
            ive 2 BBC3 and BBC TES 3 both 10772MHz h 22000, both workin fine if thats any help. pic included
            • dick b
              • Jun 2009
              • 2462
              Originally posted by acestu
              Hi Fellas,
              Acestu
              cbbc is the same frequency as bbc3,cbeebies is the same frequency as bbc4.If you want to seperate them and have two seperate channels you can on the technomate receivers go to the "add channels" menu and put the cbbc frequency(10.773H 22000) in the transponder line but put bbc3 in the channel name and Vpid=5200 Apid=5201 Ppid=5200 then save and this will add bbc3 as another channel so that you will then have a cbbc channel and a bbc3 channel.you can do the same for cbeebies/bbc4 frequency 10.803H 22000 Vpid=5600 Apid=5602 Ppid=5600.but its not like the way sky block the channels not in use you will get both cbbc and bbc3 on each others channel.(Apids can end in either 1 or 2)
              I dont know your box but it should have a similar function or perhaps you can just re-name them.
              • themanfromuncle
                • 24
                Hi Fellas,
                Acestu
                BBC 3 and BBC 4 are only on after 7pm GMT.
