What Lnb for 16.0E ?
  • albaniansniper
    • 132
    As everyone here know that 16.0 E has a very weak signal (especially digitalb) just a thought meaby a good lnb should improve the quality for that specific satellite.
    At the moment I have a Golden Interstar Universal single LNB 0.2dB with a triax 90cm but I have just order an new triax td110 1.1m Wich i thing should be more then enough.
    Does anyone recommend a single lnb universal for this specific satellite?
    Regards.
    * Dreambox 800 HD se
    * Kryptview a780
    * Triax TD110 1.1m Solid Dish
    * Birds: Eutelsat 16e/ Astra 19.2e/Astra 28e
  • opsmonkey
    • 5379
    I'm using a Fortec Star 0.2LNB which cost ?5.. works fine in any weather on all transponders.. The dish size is more key to 16E
    • owenb
      • 703
      mate you should be able to pick up 16e with a 90cm have you checked your setup?
      • opsmonkey
        • 5379
        I'm using a 1m in Harrow with no probs
        • albaniansniper
          • 132
          I do get a ok signal around 60%-70% for the digitalb but I also do have a clear view no trees or buildings so just a thought really if i can do better then 70% ish?
          A view of my satdish down below.
          * Kryptview a780
          • opsmonkey
            • 5379
            I'm on SNR 85% AGC 94% with a 1m (?50 dish) and 0.2LNB (?5) on Supersport 4 right now
            • owenb
              • 703
              mate 70% defo is not a weak signal i only get 79% with a 1.2m so i dont think u have any problem to be honest, i get 100% for sky italia and most on 13e
              • albaniansniper
                • 132
                Thanks for the suggestions.
                Regards.
                * Kryptview a780
                • mdt
                  • 3034
                  different recievers have different calebrations on the tuner which gives you your quality reading. you should be ok for the majorotie of transponders on 16east but not all, saying that the d****alb/t***g transponders are strong. dont worry about the sq readings as these are only a general guide and are not definate. if you have a strong reliable signal in all but the most terrible weather then your set-up is fine. regards mdt
                  • albaniansniper
                    • 132
                    Def...agree MDT.
                    I should get more then 70% in few days time now that I have purchase the new triax td110.
                    I shall wait & see.
                    * Kryptview a780
                    • albaniansniper
                      • 132
                      Update:
                      They say the size doesn't matter but let me tell you that it does matter. Haha
                      The triax td110 1.1m dish did the trick. From 70% went to 96%
                      You get the picture now .
                      * Kryptview a780
                      • owenb
                        • 703
                        brill mate thats gr8 i tweaked my 1.2m and got 92%
                        • albaniansniper
                          • 132
                          Cool Man,
                          Now >>>>> 96% was meter using technomate 5400+ & Protek 9600ip Receivers.
                          But now I bought a spiderbox receiver sd 5000 and it shows differnt % around 75% for 16.0E and 80% for Hotbird & astra. What is going on? wich one is right now?
                          * Kryptview a780
                          • mdt
                            • 3034
                            Cool Man,
                            hi m8, the spiderbox recievers seem to have their onboard tuner calibration set to a lower level and this is why you are getting a 20% difference in sq readings. dont worry about it as these readings are only a general guide as ber is much more important when trying to get a stable signal. ive had a stable picture off 21.6e using a 9000hd with only a 15% sq reading on a scpc mpeg2 signal. as long as your picture/sound is ok in all but the worst storms then your system is fine imo. regards mdt
