Hi does anybody know if the carling firmware for the hd combo will work on the new starview 9600 caci please , or does anybody know if this receiver already has software cccam and newcam on it ....
Acestu
If my post Helps, then Please Click the THANKS Button ,as i will do for you.
------------------------------------------------------------------------- The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
HI I have this reciver and yes is your answer to your question although you cannot access the cable side obviously as its a sat reciver...basically its a HD combo without the cable tuner although there is space for it inside the box!...yes CCCam ...works fine ..
I have all the firmware necessary so if you need it pm me ..but in the downloads section its there also!
