has recent high winds broke dish?
  • Wingnut
    • 376
    hi lads,can someone give there expert advice please, im currently using a dm800s with a 1metre motorised dish which was installed by some installe,signal was great on most sats and all was well untill the winds came,after the winds went i tried all sats and got no signal,so i new winds had knocked my dish of course, i went up the ladders and had a look and the pole is 100 percent still straight as its well bolted in,the dish is 100 percent straight to the motor still also,so i thought this would be easy then,i used sat metre and found 28.2e ok,lined dish up to it,tried dreambox but only gettin 64 snr, went to positioner setup and tried fine moving dish left and right but signal just got worse,then tried moving dish up and down etc at all angles were i was gettin signal but cant get over 64snr,no matter what angle i try ,up,down ,left ,right etc, 64snr is the highest, checked lmb and that seems if it hasnt moved also, could it be possible the lmb is damaged?if it was damaged would i even pick up a sign? also all cables etc seem ok,havent came loose or nothing,could it be possible i need to change coax wire?the latt and elavation on motor look like they havent been moved also, im just really baffled here,im no pro at this but i mean if i am gettin signal of 64snr and no higher i starting to think my dish or something is broke now even tho all looks ok,any help here wud be brill,really doin my head in,look forward to some replys,thanks
  • owenb
    • 703
    na i doubt the dish is broke mate or the lnb ( possibly tho) i had to get a pro to do mine in the end a few days ago, he said my elevation had moved therefore couldnt get the arc right he tightened a few bolts got his ?3000 sat meter out and within about 2 mins i had 100% on 13e and 85% on 4.8e. without a sat meter u really are on a hiding to nothing mate i tried for hours to do it. it sounds similar to my prob as i could only get 13e and had a 51% signal.
    • Wingnut
      • 376
      well owen thanks again for info, spend over 2 days at it alreadyv , the sat metre im using is just a spupid chaep thing but seem to find me 28.2e anyway, i thought the sat metre on the dreambox would have done the job,il have to hunt for installer again ,
      • Rodbouy
        • Jul 2010
        • 1320
        a cheap sat beeper is ideal mate. Just put the station on BBC1 and have the tv close if possible. Then goto www.dishpointer.com and get your line of sight. Once on that site pick a point to focus ure dish on and then move the dish left and the tile back and forth till you hear it sequel via the beeper.
        if you dont hear any noise variation then the lnb could be beat but I doubt it. They are quite durable.
        It can be a pain some times but keep at it, you will feel better for it and saves you any hassle in future.
        • owenb
          • 703
          totally agree rodbouy a sat meter should do it, i spent 3 days trying to get mine going properly and could still only manage to get 6-% on 19.2e and no other sats
          there comes a point where ur brain is just mush and u need help with it and after 2 days i just thought i better ring a pro as u can only fiddle so much plus the mrs was ready to kill me for going on the roof 30 times
          • Rodbouy
            • Jul 2010
            • 1320
            Woman never understand
            When I first put my dish up It took me two days of messing about by the time you notice all your silly mistakes, but of course the 1st attempt she replied "So that it broke then? Waste of money"
            Bloody woman.
            • owenb
              • 703
              HAHA EXACTLY THE SAME MATE!!!!!!!!! She was saying oh bloody hell u always get what u want then i reminded her that we had just bought her a 25 grand new var but it was the end of the world when i had to sepnd ?100 Sorting me sat out
              • Rodbouy
                • Jul 2010
                • 1320
                pmsl all the same then .
                • owenb
                  • 703
                  certainly are mate
                  • Wingnut
                    • 376
                    i did try with a sat metre, its was 15 pound for it so prob crap, it told me i defo had full signal but checked and only 64snr, defo will never go over that snr
                    • dick b
                      • Jun 2009
                      • 2462
                      are you sure the sat meter found 28.2E? cheap sat meters will only tell you your on a sat not which one.It still sounds like your dish/motor shifted on the pole,or the dish is not 100% central on the motor spigot it only has to move a fraction to be out.either way it sounds like you need a complete re-align
                      • owenb
                        • 703
                        yep exactly what i had to get dickb
                        • Wingnut
                          • 376
                          yes mate defo on 28.2e as when i check dreambox channels clearing ok on 28.2e,i ended up taking dish of and then put up again straight which looks like it is but still only hittin that snr,i mean im no expert but do think i need it realigned again,im waiting on a guy phoning me about fixing it
                          • owenb
                            • 703
                            yeah realign is need imho mate what sort of snr did u used to get?
                            • DJSimo
                              • 453
                              Ive just had to adjust mine after the winds, dish only needed lifting, just a few mm, and perfect signal again throughout the arc from 45?E to 45?W, would get 53?E too but there is a tree in the way, the winds will take it down one day(or I will)
