Football First Frequency's
  • melloned
    • 1215
    Can anyone give me the frequency's for the sky football first "match choice" channels ?
    Cheers
  • opsmonkey
    • 5379
    They'll be on the Sky Sports Active frequencies:
    10876 V SR 22000 FEC 5/6
    12070 H SR 27500 FEC 2/3
    • melloned
      • 1215
      Thanks Ops and a fitting tribute to a football manager all should be judged by , a true legend !
      • melloned
        • 1215
        Hi Mate i added the frequencys and did a auto transponder scan , but all's i got was sky active ads Mate .
        will i have to scan again when they're transmitting , or am i doing something wrong . Thanks
        • opsmonkey
          • 5379
          They only broadcast the matches when the programs on.. Outside of that then it'll be looped ads
          • melloned
            • 1215
            I only have a sky dish up now mate , but i had these channels on a provider called sky digital , when my motorised dish was up and the channels were listed ad sky active 1-9 , but i lost these frequency's when i reset my dreambox and went to a single sat set up , i should have made a note of them ! I'll try a rescan when they're transmitting again Op's .
            • melloned
              • 1215
              no joy with these frequency's when i scanned during match choice Mate , the last one's i had were sly active 1-9 channels . anyone know them ?
              • SGTFlipFlop
                • Sep 2009
                • 1002
                Its all setup on my bouquets, Have a look at them and copy them
                • EMPB
                  Some receivers do not see the PIDs for these channels.
                  eg on 10876V my Topfield only see's the 4 Nickelodeon Channels.
                  So Advance Scan / Manually inputting the PIDs may also be required.
                  • piopat
                    • 708
                    those channels are seen by a dreambox as data channels as opposed to tv channels ,so on a dreambox you have a couple of options one is to use dreambox edit to change the channels on those frequencies from data channels to tv channels (you can also do the same for the bbc red button sports ) or you can use sgt flipflops excelent bouquets .
                    • johnny99xx
                      • 45
                      I hope this helps
                      I have a vu+duo and all I do is download the multiquick pluggin, select subservices (yellow button), restart and all subservicrs appear (open pli image)
                      I have football first 1-7 but there actually broadcasted on channel NAME (not number) 1471 upwards)
                      freq 12070000
                      symbol rate 27500000
                      polorisation Horizontal
                      fec 2/3
                      if you need any more info, let me know
                      • melloned
                        • 1215
                        Try as i might , i'm still without the football 1st channels, i've manually added frequencys and scanned, find no more than channels i already have.
                        I've tried loading Sgt Flip Flops sky uk bouquets, using dreambox edit and it all completes fine, but when i reboot the dreambox , i can't find anything other than the channels i previously scanned in using the automatic transponder scan, where do they live ?
                        Anyone help please ?
