what other sat can I pick up with a sly dish
  • jfish
    • 799
    managed to get a sly dish/lnb from neighbour (before some local thief nicks it from neighbours garden).. what other sat can I pick up with the sly dish ...
  • Manic01
    • 5117
    Aim at 13e or 19.2e and maybe 39e.
    • dick b
      • Jun 2009
      • 2462
      if its a zone 1 45cm dish I"d forget it.if its a zone 2 19E is probably your best bet and 13E. to be honest I"v never tried to get european sat with less than 80 cm and that will bring all the major ones in ok,as you have it you can try it with nothing to lose and let us know what you can get but dont hold your breath.
      • mdt
        • 3034
        also try 45e and 5w, regards mdt
        • jfish
          • 799
          thanks.. did a quick look on dish pointer for the sats mentioned and all seems to be good for me .. I am in West Yorkshire (Dewsbury) .. will give it a go this weekend ...
          out of curosity which one of the sats mentioned (45e, 5w, 13e, 19.2e, 39e) can I get 3pm Premisership games.
          • Manic01
            • 5117
            39e using bulsat keys in suitable stb.
            • calhib
              • Sep 2009
              • 236
              39e with softcam and 19.2e and 13e with either a legit subscription or cs
              • jfish
                • 799
                using dish pointer, and entering my post code - these are the sats I can pick up with Zone 1 dish
                0.8W INTELSAT 10-2, THOR 3,5
                * 22.0W NSS 7 with 55cm Dish
                27.5W INTELSAT 907
                39.0E HELLAS SAT 2
                13.0E HOTBIRD 6,8,9
                19.2E ASTRA 1F,1G,1H,1KR,1L,1M
                28.2E ASTRA 2A,B,C,D, EUROBIRD 1
                23.5E ASTRA 1E,3A
                • jfish
                  • 799
                  which softcam - MGCamd (that is what I am using on my DM500S at the moment)
                  • Manic01
                    • 5117
                    You need modified mgcam 135a
                    Those stats look dodgy, 0.8w on a sky zone 1 dish.
                    • jfish
                      • 799
                      according to dishpointer.com when I entered my post code it gave a list of all satellites what what I can get with what size, and from that 0.8W beam INT10023 53, I can get with a 50cm dish
                      • Manic01
                        • 5117
                        I would strongly disagree with those figures if you are in UK.
                        • jfish
                          • 799
                          thanks for that, have decided to go with 39E and get Bulsat and try to get 3pm kick off
                          • jfish
                            • 799
                            another point I need clarification on
                            the second Sly dish I have was locked to 28.2E when on the wall, in order to point it to 39E - will I need to adjust the dish itself .. move it up or down, left or right
                            also any plugins on the DM500 I can use when setting the disj up so it will tell me when I get a lock on a satellite or will I use the signal strength as a method to see I am getting the strongest signal
                            • mdt
                              • 3034
                              from behind the dish you need to move it to the left and slightly down. if you dont have a proper meter then install a channel list with dbedit for 39e and then select a fta channel and turn the volume up very loud. when you here music/voices booming out check your sq readings. i really think you are wasting your time as bulsat are dropping ir2 anytime now so the 3pm games wont be available via softcam much longer anyway. get yourself a gibby/triax dish and a motor for around ?100 and then google cs. good luck anyway!, regards mdt
