How to Multiboot from an AB IPBox HD using a USB stick.
Format USB STICK to FAT32 , then unpack the file below and rename it usb_upgrade.img and transfer it to the usb stick.
Remove the USB Stick from the PC then drop down the front panel on your AB IPBox HD and press the round Standby button and the ok
button together and let them go to put the box into standby.
Insert the USB Stick into the USB Port at the back of your IPbox HD
Hold in the Standby button on the front panel and then when the box states BOOTING in the front display press the UP button and
then release both buttons, USB UPGRADE should be displayed in the LED display.
If this giets you Err 10 or stops on booting, open PCeditor ( latest ), and flash it using the normal methos for flashing an image.
In the box LED you should see it go to Erasing, then go to Flashing, this will only take a few seconds.After that it will say done.
Time to re boot your box holding the relevent remote control key number to boot from your desired device.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
3) original images
7) boot from flash
