Hello, I have the problem that time shown on screen is different from the one that is shown on the box in offline or standby mode with nlb9341 image. Ithink the problem happened before with ann earlier version - but was fixed in versions between. Anybody an idea on how to fix?
Time setting problems with nlb 9341 again?
I have the same problem on 9000 and I have done anything which is said here !!! but I think the problem started after installing E2 on USB and using E2 sometimes, there is some problem using multiboot E! and E2 imagesComment
if you are switching between E2 and flash image you will experience time changes, E2 normally is ok.
Its the flash image what changes the time, you need to update time in the setup options.
Or you could leave 1 image on all the time to guarantee the time is correct.
When i boot box after being on E2 image to flash i always update the time first before anything else.
I hope they can fix this bug as ive mentioned this to them many times
