Cuberevo / mini Emulators
  • grizzlyt
    • Oct 2008
    • 93
    #16
    IncubusCamd ver 0.8.3+ NewCS 1.66
    NewCS - 1.66 RC1
    Changelog
    v.1.66 RC1
    All cdks are new, due to server crash.. many many changes to libs etc.
    Support for TNTSAT.
    Experimental support for *** 0963. NB! Remember to put the 4 byte hex boxkey in config!
    Multi-realms added to chameleon.
    Support for pin-code on specific channels specified by in config.
    Added the ability to disable/enable certain virtualcards on chameleon in config, or disable whole list.
    Quote:
    NB! NewCS has gone green - removed all support for windows
    Time to grow up, get a powerfriendly little linux-device to run NewCS on!
    coming soon on our panel...
    wait please
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
    • robbsson2000
      cant get softcam to work
      hi all i cant get the incubus to work.. cant dowload plugins in the black pearl img.
      and the incubuc 5 don?t work .
      please help..
      • aftermath
        • 4345
        #18
        I take it its a Kathrein box you got ?
        • fredh
          • 7
          #19
          Config
          Please find config as requested, I am never sure if you can remove all the garbage and just leave the server details:
          # incubusCamd configuration file #
          # All configuration options in this file observe the same format: #
          # <configuration_name>=<configuration_value> #
          # Each section are [<section_name>:<option_1>:<option_x>] like. #
          # No matter about white spaces on any place or UNIX/DOS style files #
          ########################### general configuration ############################
          [General]
          # Enable (1) or disable (0) background execution
          # 0 - Off
          # 1 - On
          background_execution=1
          # This sets the level of console output for debugging:
          # 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
          # 3 - Print all debug messages
          debug_level=1
          # This option enables (1) or disables (0) the writing of debug information to the
          # console.
          log_to_console=1
          # This option enables (1) or disables (0) the writing of console output to a log file
          log_to_file=0
          # When log_to_file is set to 1, this is the path and filename to write console
          # ouput to.
          logfile_name=/var/bin/incubusCamd.log
          # Used to activate on-screen messages. Username and password required if
          # HTTP authentication is enabled on enigma.
          on_screen_messages_show=1
          on_screen_messages_username=root
          on_screen_messages_password=
          on_screen_messages_key_update=1
          on_screen_messages_wait_for_key_update=0
          on_screen_messages_ecm=0
          on_screen_messages_emm=0
          #When activated, camd will listen on the specified port for connections. All
          #log activity will be broadcast in real-time to connected clients.
          console_logs_broadcast=1
          console_logs_broadcast_port=666
          ############################ caid configuration ##############################
          # First of all the cam use the incubusCamd.prio file, then use the
          # configuration below.
          # Sections are defined by the value of the CaID.
          # You can choose the default ecm table used by the codify, this means that
          # you can choose the first byte of the raw ecm that is downloaded from sat.
          # If you don't know what value to insert, use "80". (all value are in hex)
          # Default value for ecm_table is 0x80.
          # The option "priority" tells if one caid should be selected before try
          # another one with a priority value greater.
          # The less is the value the greatest is the priority. Choose from "0" to any value,
          # priority value is decimal.
          [CaID:0100]
          ecm_table=80
          priority=1
          [CaID:0500]
          ecm_table=80
          priority=1
          [CaID:0600]
          ecm_table=80
          priority=1
          [CaID:0919]
          ecm_table=80
          priority=1
          [CaID:093B]
          ecm_table=80
          priority=1
          [CaID:0B00]
          ecm_table=80
          priority=1
          [CaID:0D00]
          ecm_table=80
          priority=1
          [CaID:1700]
          ecm_table=80
          priority=1
          [CaID:1800]
          ecm_table=80
          priority=1
          [CaID:2600]
          ecm_table=80
          priority=1
          ########################### provider configuration ###########################
          # All parameters are in hexadecimal notation.
          # Each section is defined by the provider id value.
          # If you don't know the provider id value then use the provider id "000000" and ca id "0000".
          # On provider 000000 caid 0000 goes all provider wich are not declared. If the provider
          # is declared then the cam will use the provider founded.
          [Prov:000501:CaID:1833]
          # Decoder type indicates whether the cam will attempt to decode this provider
          # in software, or through a card-server. Supported values are:
          # 0 - Use internal softcams.
          # 1 - Connect to a card sharing protocol card-server.
          decoder_type=1
          # URL of card-server to use, formats are as follows:
          # newcamd://<username>:<password>@<hostname>:<port>/<des_key>
          # aroureos://@<hostname>:<port>
          # radegast://@<hostname>:<port>
          # Example:
          # newcamd://foo:[email protected]:12345/0CE3476FF2E1C9D9A0A109B371E3
          # Multiple card-server url's can be specified for server fail-over.
          # If the emu fails to connect or fails to get valid CW's, it will try to
          # connect to other servers in a round-robin fashion.
          # Up to 16 servers can be added from index 0 to 15.
          # You can choose also to select a cccam or gbox server, but they must be declared
          # in the "servers configuration" section ( [Servers] ).
          # e.g. : if you want to use a cccam server for a provider you must put it on
          # the parameter card_server_url_0=cccam://
          # NO MATTER the value after the double slash because server configuration is
          # made in the section [Servers].
          # Only for newcamd, radegast and aroureos is usefull to put correct connection
          # parameters because they are provider dependent.
          # Example i want to use mine card into the slot with newcs for prov 0501 on nagra3 (caid 1833)
          card_server_url_0=newcamd://username[email protected]:10550/0102030405060708091011121314
          [Prov:000000:CaID:0000]
          # this provider is a stand-in for all cards and all caid not declared previously
          # For example I choose to use cccam protocol on all other provider.
          decoder_type=1
          ########################### servers configuration ############################
          [Servers]
          # This is the section for the multi-server configuration.
          # cccam://brianblythe2006:ser732009@xxxxxx:12000/<receive_emu_shared>/[EMM]
          # where <receive_emu_shared> should assume value "yes" (without quotes, if you like to receive emus data shared by the server) or "no" (this is assumed by default)
          # gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>/[EMM]
          # NOTE: The "EMM" suffix is optional and tells the card-server client whether
          # to send EMM's to the card-server or not. Enabling or disabling this only
          # has effect if the card-server is configured to accept emms from this client.
          # NOTE 2: The "card_server_url" is not the same as previously declared in the prov/caid section
          # use how many server as you like
          card_server_url=cccam://brianblythe2006:ser732009@xxxxx:12000
          card_server_url=cccam://<username>:<password>@<hostname>:<port>
          card_server_url=gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>
          ########################### CaIDs tunneling configuration ############################
          [CaIDTunnel]
          # All values are in hex notation
          # In this file you can configure what CAIDs/PIDs incubusCamd should tunnel to another CAID
          # situation 1: this caid, all idents, on all channels will use the tunnel_caid
          # caid:tunnel_caid
          # situation 2: this caid/ident pair will use the tunnel_caid
          # caid:tunnel_caid:ident
          # situation 3: this caid/ident pair, on channel 'sid' will use the tunnel_caid
          # caid:tunnel_caid:ident:sid
          # i.e:
          # 1833:1702:000000:0082 # this one should tunnel premiereHD nagra3 into betacrypt cards
          # 1833:1702:000000:0081 # this one should tunnel premiereHD nagra3 into betacrypt cards
          Many thanks in advance
          • grizzlyt
            • Oct 2008
            • 93
            #20
            Hypercam 1.0.4 multi receivers
            Hypercam 1.04 multi receivers
            Release 1.04
            => Added one type of *** card support
            => Added hypercam.status file, see configuration file for settings
            => Fixed clear => crypted switch for some channel not providing new PMT
            Thanks for Hypercam Devs for this piece of software !
            hypercam.1.04.7z
            Dreambox 7025-SS
            • ipbox2008
              why in start of task there are this errors:
              cuberevo-250hd:/var/bin# start_hypercam.sh
              killall: mgcamd: no process killed
              killall: mg_launcher: no process killed
              killall: newcs: no process killed
              rmmod: sci: No such file or directory
              killall: hypercam.ipbox: no process killed
              /var/bin/api3-wrapper.sh: line 9: syntax error: "(" unexpected
              /var/bin/start_hypercam.sh: line 12: /var/bin/sci-ng.sh: not found
              Is non compatible with cuberevo 250hd?
              thank's
              • satman
                • 736
                #22
                mgcamd is not running
                mgcamd_launcher is not running
                newcs is not running
                hypercam is not already running
                driver is probably already loaded and/or the .sh script files is missing from /var/bin
                only tested with 9000HD but dont see why that would stop working on 250HD
                thank's
                see RED.....
                boom!
                • grizzlyt
                  • Oct 2008
                  • 93
                  #23
                  Hypercam 1.05
                  Hypercam 1.05
                  => Fixed clear => crypted switch / Dreambox PPC specific operations
                  => Workaround for Dreambox PPC poor smartcard drivers timing...
                  hypercam.1.05.7z
                  Dreambox 7025-SS
                  • grizzlyt
                    • Oct 2008
                    • 93
                    #24
                    Hypercam 1.0.6
                    Hypercam 1.06
                    Release 1.06
                    => Fixed card support on Dreambox PPC for N2/N3/IRDETO/***
                    => Fixed streaming decryption on Dreambox PPC
                    Dreambox 7025-SS
                    • despdan
                      • 544
                      #25
                      Originally posted by grizzlyt
                      Hypercam 1.06
                      Release 1.06
                      If we ever get a card dumped will this clear the channels on Irish n2 stream on a dreambox?
                      • satman
                        • 736
                        #26
                        @dan yes it will
                        boom!
                        • kaneguru
                          • Jun 2009
                          • 4
                          #27
                          thank you.
                          did it work on qbox_hd also?
                          • kaneguru
                            • Jun 2009
                            • 4
                            #28
                            hello.
                            on my qbox run newcs well.
                            another receiver like dream or dbox can connect to my box also well.
                            but myself cannot connect to newcs.
                            not incubus or hypercam.
                            what make i wrong?
                            in incubus conf i activated newcamd line.
                            can anybody help me?
                            thx
                            • aftermath
                              • 4345
                              #29
                              IncubusCamd 0.85
                              IncubusCamd 0.85
                              18/06/2009, V0.85
                              - deleted old priority system for caid, now will be used firstly the prio and then a cycle selection
                              - SID in hex value instead of dec one
                              - fixed some bugs on caid ecm parsing
                              - fixes for stability/less-crashes (crashes were made by the pmt handling, using pmt file wich the writes is slower than the channel change,
                              now should be fixed in almost all cases)
                              - still open the 2.1.1 protocol support and previous version
                              - fixed a bug on reading keys for the internal emulator, now also unsupported softcam.key files are skipped in the unknown fields
                              (read the softcam.key file to see how to build a new one)
                              • kaneguru
                                • Jun 2009
                                • 4
                                #30
                                hi.
                                i have incubus,but i will use my softcam.key for digitv.
                                what should i do?
                                i have write follow lines into the conf
                                [Prov:002111:CaID:0000]
                                decoder_type=0
                                but the didn?t work.
                                whats wrong?
                                thx
