Can't flash anymore. Please Help
  • xcargot
    Hello everyone,
    I just bought a Vizyon HD820, which is, I think the same thing that an IPBox 910HD, CubeRevo 3000HD, CubeRevo mini2.
    I first tried some DGS images. I've found the UI very slow (I own a DM500S). I've always flashed them through the menu and a USB stick.
    After that I flashed an Enigma 2 image, found on the SIFTeam website (Enigma2 NightlyBuild 0.7.0). Same thing, I flashed it through the DGS menu.
    Problem : no upgrade software menu in Enigma 2.
    There is an other method, the USB host flash, but I haven't managed to get it to work !
    Hard Shutdown (Power + OK), then Power and Up. I tried, I tried, pressing in every possible way these buttons, I never got the USB Flashing message on the dot screen.
    I though maybe it's a uboot issue, even the 910HD should have a recent enough uboot. But same thing, not possible to get the serial flash option at boot (power + right arrow).
    I tried by myself for hours, surfed the web as much I can stand, now I'm stuck.
    Any ideas how to get flashing USB on the dot screen ?
    Thank you
  • khan
    • 46
    hi mate
    i have a ipbox9000hd on that you have to hold power button on front and apply power and till it display usb upgrade.
    hope its of some use as u mention 910
    • xcargot
      Originally posted by khan
      hi mate
      I finally manage to flash it. It's not exactly what you said, but it helped me finding the solution.
      For the record, I switched off the main power switch, I kept Power and Up Arrow pressed, I swiched on the main power switch (keeping the 2 buttons pressed), and after 6-7 sec, the message appeared.
      Thanks anyway !!
      Regards
      • tcs_fr
        It's the first time i see that you have to press the up-arrow to enter usb upgrade mode.
        I don't know what version of uboot it might be.
        • atif
          hi
          that didnt work for me. any other suggestions?
