ok, then take out the HDD.
Put it in a PC
download Partition Manager ( use the search engine on here )
format the HDD using Partition Manager ( make sure you format in Ext2 mode ) and have 2 partitions, 1 gig for swap, and the rest for your recordings e.t.c.
Then put it back into your IPbox., If its still blacked out , then you have an incompatible HDD , ive had 1 of these myself. You will have to get a different model HDD.
If you google for compatible HDDs for an IPbox , i am sure i read a list of them somewhere.
