New Favourites channellist panel
  • sotiris70
    • 31
    This plug-in provides an alternative to the favourites channellist in the firmware.
    Its main advanteges
    - Sorts your favourites groups as defined in PCEditor
    - Allows to switch channels in PiP or live mode (and filters channels which cannot be opened in PiP mode).
    So it can also be used as alternative to the Sub channel list.
    Key Mapping
    Up/Down -> figure it out yourselves
    Left/Right -> jump 5 entries in list
    Red/Green -> change Favourites group
    Blue -> switch live/Pip mode
    Licence
    GPL
    RELEASE 0.5.1
    - fixed panic when /var/theme folder is not present
    - automatically jump to currently active group and channel on startup
    Enjoy it,
    pacco
  • italiaboy
    hi
    hi can you plaes tell me whare to put or how to yous this files
    • sotiris70
      • 31
      Hi @italiaboy,
      With an ftp programme, copy favpip.plugin to var/plugin
      Then at your box menu, go to plugins and you will find it there
      • italiaboy
        hey thnx mate
        ok many thnx mate
        • italiaboy
          problems fav
          can someone help i have the 910
          and have download de fils
          but have
          favpip-v0.5.1
          favpip-v0.5.1.bak
          i have put it in var/plugins and nothing have change extension to plugins
          and see it in my plugins via menu bud cant acces it
          what am i doning wrong
          • sotiris70
            • 31
            but have
            favpip-v0.5.1
            favpip-v0.5.1.bak
            @italiaboy, in var/plugins CHMOD to 755 the favpip.plugin
            • sotiris70
              • 31
              RELEASE 0.6
              - show epg next to channel names
              • kariv
                Ok
                Ok I hope this works
                • sotiris70
                  • 31
                  RELELASE 0.9.1
                  - configuration files can have line end in both formats 'LF' or 'CRLF'
                  - favpip.config is looked for in plugin folder, which is defined by sbox. Should work on DGS and ABCOM firmware.
                  - header shows positions of SCRAMBLE and HIDE icons.
                  - HIDE icon in header represents state of hidden channels visibility.
                  • sotiris70
                    • 31
                    RELELASE 1.9.0 - RC for 2.0.0
                    - whole code was rewritten and now is using widget libraries.
                    - no more global variables
                    - navigation is now 5 times faster then in previous ones.
                    - new configuration options for fonts setting added. They still need to be fixed to check border values.
                    • sotiris70
                      • 31
                      RELELASE 1.9.3 - RC for 2.0.0
                      - transponder is now set correctly in live channels, so pip filter works good.
                      - switching to second empty group when empty groups are shown was not possible, not it is fixed.
                      • cracklehead
                        tx gonna try this plugin :-)
