Problems on itgate 220 tgs
  • plasterer
    • 1631
    #16
    Try and FTP it into the tmp folder
    And upload via the remote
    rename it TGM220_update ,Lets know ............Paul
    PAUL
    • eaglesnfl
      • Jul 2011
      • 10
      #17
      hi Paul, at the end i have been able to riwrite the firmware on my itgate. Now every channels sat are there, but it is still not recognize the dtt tuner. thanks a lot for you help.
      • andiewill
        • Aug 2008
        • 490
        #18
        Did you do a factory reset after flashing ? Once you have done that it will detect your tuner all should be fine.......
        ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
        • eaglesnfl
          • Jul 2011
          • 10
          #19
          thanks for you advise, i have done a factory reset after sending the imagem but it did not work as you can see by this photo it has been recognize only the sat tuner, or maybe is the dtt tuner showed in another section? seeing it you can give the right advise. Ciao
