Itgate 200 Satellite
  • ns77
    • Jun 2009
    • 35
    #16
    tried that image bugsy BUT,not sure what i'm doing wrong,i have changed my cable 200 to a satellite box,so it still has loads of cable software on it,scanned 28.E got all the FTA channels,tried to flash your image on,goes through all the lines scrolling down screen after about 10 mins it says update finished .then in big letters LOADING ERROR,so power off reboot & it goes back to my uruk 7.9 image..i cant manually put cccam on box as not enough room due to all cable & sat files,any ideas,tried 3 different images now.must be something im not doing
    • plasterer
      • 1631
      #17
      Cam should fly onto that image
      Its here if you need it shout
      Delete the cables XML , if your going to stick with sat
      You will have to add CCcam.cfg as well............Paul
      PAUL
      • ns77
        • Jun 2009
        • 35
        #18
        Cccam
        tried putting a cccam file in the uruk 7.9 image,put in the folder goto box manual install,but cant see the file,so tried a couple of other cccams,unless i'm trying to load cccams that arent compatible with this image,which is why i thought i might flash a new image & start again,mainly to get rid of all the stuff that was loaded when it was a cable box,
        • freck
          • 1076
          #19
          Manually install this one,works perfect for me....use the full.tar.gz.,or even ftp both of them if you like....one works defo.(if youve just changed the tuner to sat do a factory reset first to delete var....thatll dump all the cable info)
          Ftp to tmp and install manually and the cam will show up in your cam menu...cccam.config also in var/etc.
          Freck
          • ns77
            • Jun 2009
            • 35
            #20
            Cheers Freck will give it a try,still cant figure out why it wont accept a new image,but if this works i'm not bothered....i'll be back.i suppose with a new image you can use download function where as my image keeps trying to conect to satkings site..
            • freck
              • 1076
              #21
              Yeah satkings are no more...so server also gone.But you should be able to get cam from EDG server if you have their image on...funny.To gain any access to a server DHCP must be ticked in network settings to get you online.
              UKUR 7.9 will be fine tho so just ftp in the cam and manual install and you should be fine...let me know.
              Freck
              • shamusbhoy
                • 66
                #22
                After you ftp to tmp where on the box is manual install is it in menu setup expert setup software update manual update?Still can't see a file.
                sigpicSubbuteo say no to newco
                • ns77
                  • Jun 2009
                  • 35
                  #23
                  oh bugger, right got the cccam manually installed rebooted,goto smartcam panel go to cam menu can only see evo cam & hypercam but no 2.1.4,,by the way running ukur 7.9 wont let me flash EDG for some reason..
                  • ns77
                    • Jun 2009
                    • 35
                    #24
                    just noticed if i go to retrieve ip address it says no internet connection available,check settings....but there is a connection,dont think this will affect seeing the cccam in the cam menu
                    • shamusbhoy
                      • 66
                      #25
                      It should'nt if you are doing it manually just managed to get cccam on mine using 7.9, I was looking in the wrong place to install it.
                      • freck
                        • 1076
                        #26
                        Heres the EDG image to try out.
                        Freck
                        • ns77
                          • Jun 2009
                          • 35
                          #27
                          cheers freck will give it a go,definately need to get a new image on,all sorts of strange happenings,do i need to do a factory reset then reboot in to flash mode or do i flash then a reset.or doesnt the reset matter when putting new image on------------------------------------------------------------------------------------------------------------------------------------
                          Still doesnt work but i think i've sussed why i am trying to put a satellite image on a cable box with a sat tuner fitted so i need the TGM220 image,will have to have a look later unless any kind person can upload one....cheers boys
                          • andiewill
                            • Aug 2008
                            • 490
                            #28
                            Here you go below....
                            ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
                            • freck
                              • 1076
                              #29
                              Put you receiver into serial mode(power up and hold the "up" button until boot screen changes),scroll to serial mode and activate,then using the control centre flash with edg image......serial flash with serial cable(9 pin).
                              Control centre here
                              Freck
                              • ns77
                                • Jun 2009
                                • 35
                                #30
                                Right we are getting somewhere i flashed the image but on reboot it gets up to the point with the edg image on screen,then reboots & just keeps in that loop .quick question that image that andiewill kindly uploaded says TGM220_update.img, could this be an update to the original image ? coz if it is that would explain why it wont boot,as i dont have the original image on,gonna try another flash just in case....will let you know.........................................
                                right tried EDG tgm220 ver 4.1...4.2....4.4 all so far just go in to a reboot loop,but it will accept the original TGM 220 itgate image....any ideas ?????
                                FINALLY....got it up & running,will explain once its all sorted,(for those that have converted a cable to a sat box).does the nemesis 4.2 have the option to download Cccam? cant find it anywhere or is it a manual install?
