New receiver OpenboxS9 called BOLT HD
  • sombel
    • Oct 2010
    • 47
    Openbox S9 has improved his version to a new receiver called BOLT HD
    BOLT HD
    VERSION: HDS2-10-11-30:1323CMT
    High Definition Digital Satellite Recorder, Personal Video Recorder 1common interface
    Mainboard: 396MHz MIPS CPU, 128MB DDR400 RAM, Memory Clock 198Mhz, 4MB Serial Flash, Single Tuner, DVB-S2 demodulator
    Standard:DVB-S2 Standard (ETSI EN 302 307)
    Decode mode: QPSK, 8PSK, 16APSK. MPEG-2/H.264 Hardware Decoding, Videotext Decoder.
    Transport Stream: MPEG-2 ISO/IEC 13818 Transport Stream Specification
    MPEG: MPEG2 SD, MPEG2 HD, H.264/AVC SD, H.264/AVC HD, Supports MPEG4/MPEG2-HD/SD, DVB-S2/DVB-S.
    Tuner voltage and format: Vertical +13.5V, Horizontal 18V, Current: MAX 500ma
    CA&CI : Common Interface Slot*1,CA card reader Slot*1, 10/100Mbit Ethernet Interface
    Aspect Ratio:Auto, 16:9 Pillar box, 4:3 Pan & Scan, 4:3 Letter Box.
    F. MPEG:MPEG1 layer I, MPEG1 layer II, MPEG1 layer III, MPEG2, AC3. Multimedia Files Playback(by USB).
    Screen Format:4:3/16:9 Auto,2Scarts. Automatic And Manual Channel Scan Options.
    Audio frequency mode: Stereo/ LEFT/R-CH, HDMI Video & Audio Output (576i, 576p, 72op, 1080i
    Digital Audio Output: S/PDIF By Coaxial And Optical, YcbCr Available.
    Support DVR: DVR with USB HDD, Time shifting with USB HDD.PVR (External USB), EPG For7 Days Supported,
    USB: USB2.0 Port*1, Upgrade software & Update Channel Database Through USB2.0 Port.
    File system:FAT12, FAT16, FAT32, NTFS (only support first partition)
    MIME: Support JPG, BMP, MP3, WMA
    Language: Multi-lingual on Menu Screen Supported (English, French, Deutsch, Spanish, Italiano, Portuguese, Turkish, Russia, Polish, Arabic, Hungary.) Multi-lingual DVB Subtitle And Teletext supported, Teletext And Subtitle Out Through OSD.
    A/V output interface:YPrPb, RCA with CVBS, SCART with CVBS, HDMI(HDCP),Left/Right analog audio, output(RCA), Digital audio output(SPDIF with coaxial or fiber).
    Power consumption: 30W Max / 1W Standby (it***8217;s optional by customer***8217;s board)
    Input:100V ~ 240V 50/60Hz
    Input frequency range: 950MHz ~ 2150Mhz
    Input signal: -25dBm ~ -65dBm
  • hooley
    • 470
    Clone alert
    • the man
      • 1660
      Originally posted by hooley
      Clone alert
      avoid , x2
      • badapple
        • 2041
        See it here
        DVB receiver BOLT HD products, DVB receiver BOLT HD
        SLOWLY, OUR FREEDOM IS BEING ERASED.
        SOON, WE WILL JUST BE A NUMBER.
        IF WE DON'T FOLLOW, WE WILL BE ERASED.
        • sombel
          • Oct 2010
          • 47
          Clone alert
          Hooley you are absouletly wrong this receiver isn't a clone of Openbox s9 but an improved version of the Openbox s9.
          It was built to struggle against the fake Openbox s9 which are widespread in our market induicind ''your receiver is a clone after update''.
          BOLT HD is more powerfull than Openbox s9 because his CPU is 396MHz MIPS instead of 300MHz MIPS for the Openbox s9
          • sombel
            • Oct 2010
            • 47
            • hooley
              • 470
              Why is it using old firmware then? The version posted up there is from November last year. It was the firmware after that that starded giving clones problems. It's a clone, simple as
              • sombel
                • Oct 2010
                • 47
                this is an old firmware because the receiver comes with this firmware but you can put the latest firmware without having kind of problems like '' your receiver is a clone''
                • southpaw
                  • 2233
                  noticed this box on yaoxin.com , think its only about ?60 , seems little money for a hd box ,
                  This post isn`t to recommend it btw
                  .BASIC FEATURES
                  1) 300 MHz MIPS Processor - Linux Operating System
                  • the man
                    • 1660
                    if its not a clone then why post it in the openbox section?
                    why does it use openbox f/w?
                    how many you selling?
                    looking at your profile , bit off topic http://www.digital-kaos.co.uk/forums...06/#post808212
                    i won the west Africa lotto , but it been hell trying to get my money , so far iv sent over ?5500 to try to clame my winnings ,
                    what going on with the lotto in morocco
                    can you find out if i won pls .
                    • sombel
                      • Oct 2010
                      • 47
                      clone receiver after update should display an ''clone error'' but not bolt HD receiver. I ordered my receiver from china in alibaba web site.
                      • hooley
                        • 470
                        I don't want to give you any more publicity, all I will say about this is that it is a clone box and I will leave it up to other members to make up their own mind.
                        This may very well take the latest official firmware but who's to say the next firmware dosent causes problems. The next firmware may have a nice update on the epg ( please ) and this box may not take the firmware and then people will be on here looking for help. The original openbox is a great price as it is, for the few pound you would save buying this I wouldn't take a risk.
                        • sombel
                          • Oct 2010
                          • 47
                          maybe your are right i will try to put the latest sofware on it
                          • sombel
                            • Oct 2010
                            • 47
                            hi this is from my BOLT HD supplier
                            As we know there are some sofeware problem for Openbox/Skybox is:
                            1. Not compatible with the newest Firmware January/2011. Once flash the box with the new firmware, the screen will display a message: "your box is a clone". then the box no longer function.
                            2. Cannot watch all SKY HD Channel. And have rebooting problem during switchover among channels sky sports 1,2,3,4 +hd. For this,You can check in some fourm link
                            Cos for the poor quality of the OPENBOX S9,Thats why our company produce the BOLT HD Receiver,Till now most customer testes it the The key feature of our BOLT HD box is :
                            1. The firmware version is : HDS2-10-11-30: 1323CMT.
                            2. Support flash the latest firmware including the January/2011 version. After updated the new firmware, the box keep perfect working situation, smoothly watching all SKY HD channel.
                            3. ALL SKY hd channels are working good which approved by our european customers. no longer have the rebooting problem as openbox.
                            • bernado
                              • Feb 2011
                              • 89
                              This thread really should get deleted as spam
