Sorry meant to get back to you earlier, this is the firmware I'm using at the moment. It says the 21st but it's different when I put it on.http://www.digital-kaos.co.uk/forums...2011-a-196688/ remember to dump your channel list and c**am details before you flash so you can put them back on after.
OPENBOX S9 , Lip sync HELP
Don't use this one actually, still the same problem. I'll investigate later a different oneSorry meant to get back to you earlier, this is the firmware I'm using at the moment. It says the 21st but it's different when I put it on.http://www.digital-kaos.co.uk/forums...2011-a-196688/ remember to dump your channel list and c**am details before you flash so you can put them back on after.Comment
Still on the original firmware HDS2-10-07-11-072AMT. Was going to upgrade to the March firmware but then I heard about the lip sync problem so held off for now. Only reference I can find to Feb firmware are dump files with the channels included.
Would really like to just add the original firmware then by own channel list after the flash.Comment
Try this one lads http://www.digital-kaos.co.uk/forums...1101030405.rar
Its just firmware, no channel lists. Seems to be fine.Comment
I'm on that firmware. Lip synch is usually fine, although on rare occasions I have notice it drift slightly on a longer programme. A channel flip up and down resynchs it. The synch of Dolby AC3 audio on ITV HD (London) is pretty unreliable though, so I use ITV HD Granada, which has mpeg audio and is usually fine, the video's a higher resolution on Granada anyway. I've read others with different receivers moaning about ITV HD synch aswell.Comment
Same as myself, they are a great wee box for a bedroom or second room. If you get stuck, ask awayComment
That feb firmware is working great for me and I've not really noticed any lip sync issues. These boxes are so easy to flash compared to dreamboxes. With the dreambox after a flash it normally takes me ages sorting out plugins and settings!
Noticed the cccam client is still 2.1.4 in the feb firmware. Are there any firmwares with cccam 2.2.1?Comment
Is Openbox S9 redundant?
I have only just purchased one of these boxes.
Are these now pretty much redundant?
Looking at the firmware dates it looks as they are really no longer supported.
I have lip-sync problems, but later will be trying to the firmware above to see if it solves the problem. Does this FW work on clones? Just a little worried about bricking it
